question about distributor and ecu
Old Jun 5, 2006 | 12:33 AM
89hatcher's Avatar
Default question about distributor and ecu
can i use a obd-1 distributor with my obd-0 ecu? or do i have to use a obd-1 ecu as well its for a LS motor. any help would be appreciated...thanks
Old Jun 5, 2006 | 01:23 AM
EnSAn's Avatar
Default Re: question about distributor and ecu (89hatcher)
From what I've read you cant. I'm kind of in the same boat as you. But.... I dont see why not (guess it depends on the obd0 dizzy tho.) if they both are a 7pin set-up.
Old Jun 5, 2006 | 02:01 AM
Redline130's Avatar
The ecu and distributor have to match (OBD wise). Either use a OBD1 ecu with a OBD0-OBD1 harness adapter, or use a OBD0 distributor on the motor.
7rrivera7
May 14, 2014 03:25 AM
thirteen20CRXSi
Nov 15, 2008 08:25 AM
fin781
Jan 19, 2007 09:16 PM
SupraRXZ
Feb 6, 2006 07:05 PM
Maddox
10
Apr 11, 2004 11:24 AM
