Fully built LS VTEC Part out! Some tight stuff!!!!!!
Old Jun 4, 2006 | 09:46 PM
Tarzan's Avatar
Default Fully built LS VTEC Part out! Some tight stuff!!!!!!
I have a LS Vtec Im parting out. It has the following left. This setup made 220 whp untuned.
Eagle H beam LS Rods
JE 12:1 comp forged pistons standard LS bore with honda rings
LS block painted Gunmetal. No crank! Ready for duty!
ARP head studs
Earls stainless braided LS vtec oil line conversion
Skunk 2 Intake manifold for SI type R head ported to 70mm and port matched
BBK 70mm throttle body with all the sensors
Crower stage 2 cams 63402-2 part number. SOLD!!!!
Crower dual springs and cromoly retainers SOLD!!!!
00 Si complete distributor with cap and rotor
Unorthodox light weight crank pulley
Type R Oil pump
Type R water pump
Crank sensor
Block has knock sensor installed
Oil pan with wind tray and oil pump pickup
JDM GSR complete engine harness uncut
JDM GSR Vtec solenoid
00 Si fuel rail
00 Si injectors
Lower timing cover and bolts
All nuts and bolts to complete engine assy
Complete cam cap assy! No head!
Cam plugs, and seals
Timing belt tensioner assy
Crank gear with crank sensor cog!
Auto meter oil pressure sending unit adapted to fit the lsvtec oil line
Alt bracket
I have the complete motor minus the bare head, valve cover,cam gears and crank!
All parts have around 15k miles and looks brand new.
PM me for prices! Thanks.
Modified by Tarzan at 7:18 PM 6/5/2006
Modified by Tarzan at 7:23 PM 6/5/2006
Modified by Tarzan at 4:50 AM 6/7/2006
Old Jun 4, 2006 | 10:22 PM
Tarzan's Avatar
Default Re: Fully built LS VTEC Part out! Some tight stuff!!!!!! (Tarzan)
Old Jun 5, 2006 | 03:50 AM
Tarzan's Avatar
Damn! No one interested.
Old Jun 5, 2006 | 06:24 PM
Tarzan's Avatar
got pics now!
Old Jun 5, 2006 | 07:38 PM
Tarzan's Avatar
Dang no one buying **** anymore other than jdm bullshit? WTF
Old Jun 5, 2006 | 07:42 PM
stockcivic103's Avatar
How much you want for the whole kit and kaboodle
Old Jun 5, 2006 | 07:51 PM
Tarzan's Avatar
Default Re: Fully built LS VTEC Part out! Some tight stuff!!!!!! (stockcivic103)
1,600 That is under half price on new parts.
Old Jun 5, 2006 | 08:06 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I paid 1600 for my fully built LSvtec with sleeves...
Old Jun 6, 2006 | 02:45 AM
Tarzan's Avatar
Default Re: Fully built LS VTEC Part out! Some tight stuff!!!!!! (HybridcivicLS-T)
Sounds like you got a killer deal then. Did it come with stage 2 cams, intake throttle body rods and pistons, If so then wow! Someone needed some coke or weed bad!
Old Jun 6, 2006 | 01:34 PM
Tarzan's Avatar
Old Jun 6, 2006 | 04:05 PM
jsull.'s Avatar
price?
Old Jun 6, 2006 | 04:18 PM
Serdar's Avatar
Default Re: Fully built LS VTEC Part out! Some tight stuff!!!!!! (jsull.)
how much for the skunk2 I/M?
Old Jun 6, 2006 | 08:30 PM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tarzan &raquo;</TD></TR><TR><TD CLASS="quote">1,600 That is under half price on new parts. </TD></TR></TABLE>
$1k and I'll come pick it up.....bwhaha.
Old Jun 6, 2006 | 08:38 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I bought the sleeved block with 9.1 J.e.pistons crower rods for 1000.00 OEM bearings only had 1300miles. nothing wrong with it. bought the complete B16head for 600 with GSR cams......my friend didn't know it was sleeved becuase it's open deck. and when he bought it from the shop the sold the motor assembled, there was a mix up in a LS with stock sleeves pistons and rods and LS aftermarket sleeved with pistons and rods.
SO....I came out on top of the entire deal
Old Jun 6, 2006 | 11:02 PM
swoyEKr.'s Avatar
What wiring harness is that? pm me with a price, i need a 99-00 si or ex!
Old Jun 7, 2006 | 03:49 AM
Tarzan's Avatar
Default Re: (Quick 99)
This wiring harness is a JDM Right hand drive Gsr harness. It will not work for you it will only fit a EG or a DC2 but thanks for the interest.
Old Jun 7, 2006 | 04:24 PM
Tarzan's Avatar
Default Re: (Tarzan)
Old Jun 8, 2006 | 04:22 PM
Tarzan's Avatar
Old Jul 15, 2006 | 08:20 PM
ImportGeeK's Avatar
Pmed
Old Jul 16, 2006 | 08:55 AM
[Ennis_D]'s Avatar
Default Re: Fully built LS VTEC Part out! Some tight stuff!!!!!! (ImportGeeK)
pm'ed!
CRXsmoke
Southeast (Sales)
162
Oct 14, 2008 07:49 PM
seldon
Sep 28, 2008 02:09 PM
killerpenguin21
Jan 8, 2007 09:09 PM
