Motor takes a long time To WARM up ###############
Old Jun 4, 2006 | 05:34 PM
Ruben19's Avatar
Default Motor takes a long time To WARM up ###############
i replace my thermostat and temperature switch and every morning, i drive about 8miles and the temperature guage still on cold. car is not overheating. What else should i look for.it gets warm after a while
Is a fully buit motor and it runs great
Old Jun 5, 2006 | 12:29 AM
Cuda70's Avatar
Default Re: Motor takes a long time To WARM up ############### (Ruben19)
Pull your thermostat back out and make sure it is not stuck open.
As a precaution, I always boil some water and use a candy thermometer to check and see if the new thermostat is opening and closing at the proper temperatures.
This comes from being bit in the *** with a bad "New" thermostat once upon a time ago. The thing never opened up at all.
In your case, it appears that your coolant is not staying in the block long enough for you to reach operating temp, so my guess would be that the thermostat is stuck open, allowing the coolant to flow through the radiator before it is hot.
Good thing is that you probably won't overheat the engine. Bad thing is what you are experiencing.
Hope that helps...
Old Jun 5, 2006 | 06:07 AM
EE_Chris's Avatar
Non-OEM thermostats seem to be a gamble on both correct opening temp or even operating at all. And even if you do have OEM, what Cuda suggested is spot on (it's the procedure listed in the Helms for checking thermostat operation). The thing is, if the thermostat is stuck open, your gauge may show cold but the engine is probably hot. Coolant that isn't allowed to sit still for a second won't absorb the block heat like it should - the thermostat makes that happen. So while he's probably right with respect to warming it up in the morning, I'd have to disagree with 'continued' operation.
Did you also make sure to re-bleed the coolant system?
Old Jun 5, 2006 | 07:08 AM
Ruben19's Avatar
im going to intall the oem thermostat today.
hopefully will solve my problem
shogun1552
Feb 12, 2013 07:38 PM
e jay one
Apr 29, 2007 09:13 PM
dkdjlf
Aug 14, 2003 10:34 AM
9K
Jan 7, 2002 05:16 PM
NewYorkTypeR
Jun 15, 2001 09:09 PM
