AUX wiring kit?
Old Jun 4, 2006 | 04:16 PM
JDM-EJ1's Avatar
Default AUX wiring kit?
I'm having quite a few problems wiring up my EG Depo foglights for my EJ1. I've determined that the wiring harness that I originally got his defective. I've read that some folks here on Honda-Tech have used an 'AUX wiring kit'. What exactly is that? Where can I buy it? About how much does it cost?
Old Jun 4, 2006 | 04:25 PM
Padawan's Avatar
Darth ModerVader
Default Re: AUX wiring kit? (JDM-EJ1)
They are most likely referring to auxiliary light wiring kit, which typically contains the wiring, connectors, relay, and switch needed to install a set of fog, driving, or other auxiliary lights. The cost varies, but you should be able to find one for $10-$15.
Old Jun 4, 2006 | 05:45 PM
JDM-EJ1's Avatar
Default Re: AUX wiring kit? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">They are most likely referring to auxiliary light wiring kit, which typically contains the wiring, connectors, relay, and switch needed to install a set of fog, driving, or other auxiliary lights. The cost varies, but you should be able to find one for $10-$15. </TD></TR></TABLE>
Awesome. Thanks man. I'll try some local auto part stores around my area.
ma91sanchez
Nov 22, 2015 10:11 PM
JaydmEg
Jan 24, 2009 12:37 PM
SIvic2000
Mar 10, 2008 02:58 PM
90ed6
Dec 15, 2007 07:26 PM
EK-NICE
10
Apr 10, 2006 08:30 AM
