AUX wiring kit?
Imperious: Mod of Valor
AUX wiring kit?
I'm having quite a few problems wiring up my EG Depo foglights for my EJ1. I've determined that the wiring harness that I originally got his defective. I've read that some folks here on Honda-Tech have used an 'AUX wiring kit'. What exactly is that? Where can I buy it? About how much does it cost?
Darth ModerVader
Re: AUX wiring kit? (JDM-EJ1)
They are most likely referring to auxiliary light wiring kit, which typically contains the wiring, connectors, relay, and switch needed to install a set of fog, driving, or other auxiliary lights. The cost varies, but you should be able to find one for $10-$15.
Re: AUX wiring kit? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">They are most likely referring to auxiliary light wiring kit, which typically contains the wiring, connectors, relay, and switch needed to install a set of fog, driving, or other auxiliary lights. The cost varies, but you should be able to find one for $10-$15. </TD></TR></TABLE>
Awesome. Thanks man. I'll try some local auto part stores around my area.
