FS: 93 JDM H22A OBD1 engine (longblock) CHEAP!!!
1993 JDM H22A OBD1 longblock (bottom end and head)
http://www.ExplicitSpeedPerformance.net
The Good:
Exactly 45k miles on it
Our own Full PnP job
Port matched
SS valves
30k mill of the head
BandM FPR
8k miles since rebuild, 3 angle valve job.
When it was running compression was same across the boards 220s i believe...
The Bad:
Engine spun a rod bearing on cyl # 3. It did not let go, I knew what happened when I did it and turned it off called a tow truck and prevented damage. Took head off and head looks fine nothing let go like I said but the bearing went. This would be ideal for a project engine or grind down the crank, throw in new bearings and fire it up. Offer up.
Modified by ExplicitSpeed360 at 9:35 AM 6/5/2006
Modified by ExplicitSpeed360 at 10:11 AM 6/5/2006
The Good:
Port matched
SS valves
BandM FPR
The Bad:
ESP.net
Northwest (Sales)
Jul 23, 2008 09:50 AM
ExplicitSpeed360
Northwest (Sales)
Aug 4, 2006 01:06 PM
