how much power do these cars lose over the years?
Old Jun 4, 2006 | 02:13 PM
triple's Avatar
Default how much power do these cars lose over the years?
hey,
Just wondering how much power do you guys think these cars lose over the years due to wear and tear.
Ive got a 97 GSR with 160,000 KM's on it, someone wanna take an educated guess on how much power it has now.
Thanks
Old Jun 4, 2006 | 02:59 PM
Uncle Willie's Avatar
Default Re: how much power do these cars lose over the years? (triple)
Do a compression check. If numbers are within spec, the hp should be right around factory hp #'s.
Old Jun 4, 2006 | 03:03 PM
93_teg_CT's Avatar
Default Re: how much power do these cars lose over the years? (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression check. If numbers are within spec, the hp should be right around factory hp #'s.</TD></TR></TABLE>
Only real way to find out. If you have 160k km, and some other dude that has the same number of miles and beat the hell out of it every one of those miles, think they'd be the same?
Old Jun 4, 2006 | 03:16 PM
triple's Avatar
Should I just go to the dealer to get it done?
How much does it usually cost, and if its not up to spec is there anything that can be done?
Old Jun 4, 2006 | 05:35 PM
93_teg_CT's Avatar
Default Re: (triple)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by triple &raquo;</TD></TR><TR><TD CLASS="quote">Should I just go to the dealer to get it done? It's pretty easy to DIY, go to sears hardware and get a tester for like 20 bucks and look a tutorial on how to use it.
How much does it usually cost like 150 , and if its not up to spec is there anything that can be done?Tune up, Change plugs, wires, cap/rotor, fual filter, pcv valve, seafoam, ect. </TD></TR></TABLE>
Old Jun 4, 2006 | 07:56 PM
Okayhoang's Avatar
man i didn't even know they lose power over the years what the hell
jond
67
Jun 25, 2007 02:01 AM
igo4bmx
Jan 8, 2005 09:32 PM
direct_connect
Feb 14, 2004 07:43 AM
SupaFly_Honda
Nov 3, 2003 12:27 AM
*Boostwerks*
Apr 14, 2003 11:26 PM
