WOW! New problem! LOUD ASS SQUEAL!?!?!
Old Jun 4, 2006 | 01:56 PM
Tippyman's Avatar
Default WOW! New problem! LOUD *** SQUEAL!?!?!
When I start my car, there is this incredibly loud, annoying squeal, sounds "belty" or something. When let off the starter it goes away, and whenever I hit the gas it comes back with the revs. After a few pumps of the gas, it's gone.
Any ideas? I'm pissed...
Old Jun 4, 2006 | 01:57 PM
Exempt's Avatar
Sounds like the alternator belt too me... But it could be any of the belts...
Old Jun 4, 2006 | 02:16 PM
.Manny.'s Avatar
Touching My Member
yeah, its going to be one of the belts, see if they are loose.
Old Jun 4, 2006 | 03:12 PM
Rex-Si's Avatar
Default Re: (Exempt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exempt &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the alternator belt too me... </TD></TR></TABLE>
Old Jun 4, 2006 | 04:16 PM
Tippyman's Avatar
Default Re: (90_EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">yeah, its going to be one of the belts, see if they are loose.</TD></TR></TABLE>
That's what I was thinking. It did sounds like it was coming from the left side of the engine (from the driver's seat) so that makes sense.
Is there anything else it could be? I don't wanna leave any stone unturned.
Thanx for the help by the way! Ya'll rock!
Old Jun 4, 2006 | 05:23 PM
FernEF's Avatar
yea.. most likely thats what it is
Old Jun 4, 2006 | 06:04 PM
Got_soy's Avatar
Default Re: (Rex-Si)
its a belt
Old Jun 4, 2006 | 06:35 PM
Tippyman's Avatar
Default Re: (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">its a belt</TD></TR></TABLE>
Lol, aight. I guess I just gotta take it off, clean it, and tighten it up real snug?
Old Jun 4, 2006 | 06:49 PM
EG8R's Avatar
Default Re: (Tippyman)
Don't go too crazy on how tight it is... Too tight can be bad too...
Old Jun 4, 2006 | 07:34 PM
Tippyman's Avatar
Default Re: (skelly ed666)
Well I thought I had it good before, apparently not...
Old Jun 4, 2006 | 07:50 PM
crxnj's Avatar
yeah man you cant tighten it up to much..puts un-needed strain on everything..
Old Jun 4, 2006 | 09:32 PM
Tippyman's Avatar
Default Re: (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">yeah man you cant tighten it up to much..puts un-needed strain on everything..</TD></TR></TABLE>
I guess I'll see how tight it is now, and just go a little bit tighter. Then really tighten the **** outta the locking bolt so it won't move again!
Old Jun 5, 2006 | 02:57 AM
PINKS's Avatar
I want a CRX tattoed on my butt
You can always eliminate the alt belt and then start the car and see if it goes away
Old Jun 5, 2006 | 04:43 AM
ludesrv's Avatar
Belt is more then likely your problem. Since your taking off the belt, take off the alternator and check to see if the bearing in it makes noise, and get it tested for charge (any autoparts store should be able to do this for you). Nothings worse then having an alternator seize on you far away from home, and tools to loosen the belt to not make the engine work as hard on your limp trip home haha.
Old Jun 5, 2006 | 05:58 AM
temp's Avatar
Default Re: (ludesrv)
adjust the tension on your alternator
Old Jun 5, 2006 | 06:54 AM
si90rex's Avatar
Default Re: (temp)
i would drive around and get the belt hot and then tighten it s so when it cools it will be tight enough.
Old Jun 5, 2006 | 07:16 AM
ludesrv's Avatar
Default Re: (si90rex)
It actually gets hotter when it's idling for about 20-25 minutes then driving around. But for the price of a belt, check for cracks, you notice one, chuck it and go get a new one. Old belts stretch and wear out, factor in cracking and glazing, you got yourself a squealer.
jcskyhigh
Nov 11, 2008 03:11 PM
flatblack-h22
Aug 17, 2006 05:53 PM
pinoyboy204
Mar 22, 2005 01:42 PM
GReddy212
Feb 4, 2005 03:41 AM
esoterEK..
Dec 13, 2004 09:47 AM
