whats wrong with the AEM?
Old Apr 15, 2002 | 06:57 AM
macdaddy's Avatar
Default whats wrong with the AEM?
i just put back on the aem cai after a long winter and i realize what i have noticed every summer, after reving hard in second i punch it into third and the car bogols
it hapens every time unless i take my time while shifting into third
it doesn't happen i any other gears.
can anyone relate or mabe give an explenation as to why this happens??
sorry for the poor spelling
Old Apr 15, 2002 | 07:23 AM
ITR#00-1077's Avatar
Default Re: whats wrong with the AEM? (macdaddy)
You might just wanna reset the ECU... you need the car to recognize the change in the air consumption... if not that then I have no idea... I've never had no problems when I had an AEM in my GS-R....
Old Apr 15, 2002 | 07:30 AM
macdaddy's Avatar
Default Re: whats wrong with the AEM? (ITR#00-1077)
how would i do that?
Old Apr 15, 2002 | 07:39 AM
There are two ways you can do this... unplug the ECU and leave it unplugged for about 30 seconds to a minute and then plug it back in... the other way is to pull the ECU fuse under your hood next to the battery and let it sit for the same amount of time... by doing this you will have to reset everything in your car again.. not major things, but probably your clock and radio settings and what not... also this will let your ECU pick up any new mods done to the car...
Old Apr 15, 2002 | 07:42 AM
macdaddy's Avatar
thanx for all the help
i thought it was something to do with the midrange power lag that hapens with the aem
Old Apr 15, 2002 | 07:56 AM
Well, if even that... the midrange power lag wouldn't cause the car to bog like that... and all cars differ depending on your setup... let me know what happens after you reset the ECU if that even helps at all...
Old Apr 15, 2002 | 08:23 AM
macdaddy's Avatar
i will thanx!!
Old Apr 15, 2002 | 08:52 AM
JPP's Avatar
JPP
You can also simply disconnect the negative ground of the battery. After you reconnect whatever you disconnected, you will have to start the car and, without touching the gas pedal, let it run at idle for a good 5 minutes so the ECU can readjust to the new setting.
Old Apr 15, 2002 | 11:34 AM
B2FiNiTY's Avatar
Default Re: whats wrong with the AEM? (JPP)
Remember to have your radio code handy.
Old Apr 15, 2002 | 01:00 PM
macdaddy's Avatar
which one is the fuse under the hood for the ecu??
Old Apr 15, 2002 | 02:00 PM
macdaddy's Avatar
well i guess i'll just disconect the battery!!
Old Apr 15, 2002 | 03:01 PM
Stumpy's Avatar
hehe Yoshi needs to post his pic.
ef9itb
Engine Management and Tuning
Nov 9, 2010 11:54 AM
Rabid Machina
Jan 15, 2006 09:45 PM
rufridn
Apr 16, 2004 03:34 PM
LSVTEC96HB
Dec 11, 2002 08:03 PM
