99 SI brake job..
This is my daily driver, so I just want to make sure I got everything I need to do this brake job instead of wasting the time pulling off all 4 wheels and finding out something like the caliper fastener is a metric hex (I don't have any metric allen wrenches).
My first question is what type of fastener holds on the caliper (bolt, hex, etc.) and what size is it (if nothing else, is it standard or metric?)
My second question... it appears that all 4 calipers just 1 piston calipers just from looking at them through the wheel, is the correct? (I only got a 1 piston brake spreader is why I ask.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CamaroLT1 »</TD></TR><TR><TD CLASS="quote">My first question is what type of fastener holds on the caliper (bolt, hex, etc.) and what size is it (if nothing else, is it standard or metric?)</TD></TR></TABLE>
All the bolts you'll be removing are hex; Hondas use 8, 10, 12, 14, 17, 19, 32, 36mm sizes (JIS) from the factory - you won't find any other sizes on the car unless someone has messed with it. The bolts that hold the caliper on are 14mm I think (can anyone else confirm?). The screws that hold the rotor to the hub are #3 Phillips (a manual impact driver is the easiest way to remove those).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">My second question... it appears that all 4 calipers just 1 piston calipers just from looking at them through the wheel, is the correct? (I only got a 1 piston brake spreader is why I ask.)</TD></TR></TABLE>
They are all single-piston floating calipers. Keep in mind that the rear caliper pistons do not get pressed back in like the fronts do - they must be turned like a screw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
All the bolts you'll be removing are hex; Hondas use 8, 10, 12, 14, 17, 19, 32, 36mm sizes (JIS) from the factory - you won't find any other sizes on the car unless someone has messed with it. The bolts that hold the caliper on are 14mm I think (can anyone else confirm?). The screws that hold the rotor to the hub are #3 Phillips (a manual impact driver is the easiest way to remove those).</TD></TR></TABLE>
So all i'll just need a 14mm allen wrench for all 4 calipers then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote"> Keep in mind that the rear caliper pistons do not get pressed back in like the fronts do - they must be turned like a screw.</TD></TR></TABLE>
Did not know that. What do you use to turn the pistons back in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CamaroLT1 »</TD></TR><TR><TD CLASS="quote">So all i'll just need a 14mm allen wrench for all 4 calipers then?
Did not know that. What do you use to turn the pistons back in?</TD></TR></TABLE>
not allen wrenches, just wrenches or sockets are fine.
Impact screw driver and probably a C-clamp to push front pistons back in. Rears are screw in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M12 »</TD></TR><TR><TD CLASS="quote">
Impact screw driver and probably a C-clamp to push front pistons back in. Rears are screw in. </TD></TR></TABLE>
Alright, sweet sounds like I already got everything I need then
I just did mine (98 EX) and the caliper mounting bolts were 17mm (80% positive). I replaced the rotor retaining screws too... cause they were such a PTA to remove and my impact screwdriver got in there pretty deep.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CamaroLT1 »</TD></TR><TR><TD CLASS="quote">My first question is what type of fastener holds on the caliper (bolt, hex, etc.) and what size is it (if nothing else, is it standard or metric?)</TD></TR></TABLE>There are 2 types of bolts with which you will likely concern yourself. There are 2 Bolts for each Caliper that secure it to the Knuckle (Front) and Spindle (Rear). There are also 2 Bolts for each Caliper that secure the Caliper Body to the Caliper Bracket (actually, they are attached to the Caliper Pins, which is part of the Caliper Bracket). All of these bolts have Hexagonal Heads, but are not "Hex" Bolts (you don't need an Allen Wrench/Hex Key).
The Rear Caliper-to-Spindle Bolts are 14mm. Some cars will have Flange bolts (a washer-like tapering) and others employ a locking washer (10mm). The Rear Caliper Body-to-Bracket Bolts are 12mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thefool808 »</TD></TR><TR><TD CLASS="quote">I just did mine (98 EX) and the caliper mounting bolts were 17mm (80% positive).</TD></TR></TABLE>I just went to my car, got my shorts and my hair all fucked up, and confirmed this. Make that 100% positive... 17mm. The Front Caliper Body-to-Bracket bolts are 12mm, just like the Rears.
Definitely get a good Torque Wrench (the Click-types work great). You should also get at least a Haynes Manual
, or get the Helm Inc. Service Manual
. They'll have all the diagrams and torque specs you'll need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CamaroLT1 »</TD></TR><TR><TD CLASS="quote">What do you use to turn the pistons back in?</TD></TR></TABLE>For the Rears, you can use a strong pair of Needle-Nose-Pliers, a Hex Key, a Strong Shaft Screwdriver, or a Specialty Tool from places like Kragen or Autozone...
http://www.partsamerica.com/Pr...48410
For the Fronts, you can use your Playstation-Strengthened Thumbs. If you cannot do it with your bare hands, you need to spend more time playing video games.
But get a manual... Too many Torque Specs to list... GL!!
JasonGhostz
. They'll have all the diagrams and torque specs you'll need.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CamaroLT1 »</TD></TR><TR><TD CLASS="quote">What do you use to turn the pistons back in?</TD></TR></TABLE>For the Rears, you can use a strong pair of Needle-Nose-Pliers, a Hex Key, a Strong Shaft Screwdriver, or a Specialty Tool from places like Kragen or Autozone...
JasonGhostz
I was just looking through the haynes manual and it says that the caliper mounting bracket bolts in the front need to be torque'd to 80 ft/lbs of torque... Is that correct, the little 12mm need to be torque'd to a massive 80 ft/lbs (sounds like a lot for those bolts)?
boostedwagon
Aug 5, 2007 09:51 PM
137
10
Sep 28, 2004 02:47 PM
