Rear Shocks broken bolt
Old Jun 4, 2006 | 10:43 AM
96tegman's Avatar
Default Rear Shocks broken bolt
Hello,
Im in the process of changing my rear shocks when the bolt going through the shock and the lower arm snaped at the head.
My next plan is to grind off the nut at the other end and hammer the bolt out....but this will only work if the nut is welded onto the strut like my new shockes are....so my question is does anyone know for sure if on stock rear struts, is the nut welded on to the strut...
or if anyone has any other ideas on how to remove the bolt...
thank you
Old Jun 5, 2006 | 05:45 AM
96tegman's Avatar
Default Re: Rear Shocks broken bolt (96tegman)
bump
Old Jun 5, 2006 | 05:49 AM
DC2 Mang's Avatar
the nut on the other side is attached to the shock
you can grind it down to hammer it out, it sounds like the only solution to your problem
Old Jun 5, 2006 | 06:31 AM
DC1212's Avatar
I hope that works for ya, i tryed the same thing and the bolt was seised in the lower control arm bushing.
Old Jun 5, 2006 | 06:48 AM
-Darren-'s Avatar
Default Re: Rear Shocks broken bolt (DC1212)
did you use an impact gun to take the bolt out, when it broke??
Old Jun 5, 2006 | 06:56 AM
DSMRacing's Avatar
Default Re: Rear Shocks broken bolt (-Darren-)
Yeah, the nut on the other side is attached.
I was trying to change my rear springs and the bolt wouldn't move. Took it to the shop and they couldn't do it either, so I'll have to cut the bolt out.
Old Jun 5, 2006 | 07:03 AM
96tegman's Avatar
Default Re: Rear Shocks broken bolt (DSMRacing)
no I didnt..I guess I should have....I have no problem cutting the bolt out. My problem is once the bolt is cut, if it still dosnt come out then I'm screwed because I have to replace the bushing....anybody know how to do this..what tools are required...
thanks
Old Jun 5, 2006 | 08:48 AM
ugotdubbz's Avatar
Do a search for "LCA", lower control arm. It has been several good posts about replacing them in the last few months. It helped me know what to do before I even started to put my lowering springs on. You are in for job if you don't have some good tools.
Old Jun 5, 2006 | 09:12 AM
Sam92Teg's Avatar
Default Re: Rear Shocks broken bolt (ugotdubbz)
The thru bolt seized to the metal sleeve of the lower control arm bushing. I took a grinder and cut off the bolt so I could pull the shock and lower control arm out, then replaced bushings with Energy Suspension units and reinstalled some new Koni's, well, that was the reason for being there anyway.
Old Jun 5, 2006 | 10:19 AM
96tegman's Avatar
Default Re: Rear Shocks broken bolt (Sam92Teg)
thanks for the info...where can I get the energy bushings you got and how did you install them...did you need a press.
and how hard was it to take out the old bushing...thanks
Old Jun 5, 2006 | 10:34 AM
__oversea's Avatar
yeah, drill it out. or just get new arm. good upgrade. function7
Old Jun 5, 2006 | 07:49 PM
stumpyf4's Avatar
http://www.team-integra.net/se...=1025
Pain in the *** to hacksaw under the car but very do-able.
Old Jun 5, 2006 | 08:32 PM
weak_tec's Avatar
Default Re: Rear Shocks broken bolt (stumpyf4)
that calls for a new control arm, if the bolt doesnt come out
Old Jun 6, 2006 | 07:56 AM
Sam92Teg's Avatar
Default Re: Rear Shocks broken bolt (spoon_meeH)
Replacing rear lower control arm bushing:
$8 grinder from flee market to cut bolt, assuming it seized to the lower bushing.
Remove LCA from vehicle.
$15 torch from ACE to burn out the old bushing, hacksaw the sleeve, then use a hammer and chisel to knock the old sleeve out. Don't worry about melting the bushing, it just turns into ash.
$34 Rear LCA bushings from Energy Suspension -- Ebay
You can use a 2x4 and place it over the bushing
and stand on it to press the new bushing in.
I used a $23 Arbor Press from JC whitney/Eastwood Co., went in like butter.
Old Jun 6, 2006 | 01:48 PM
stumpyf4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_meeH &raquo;</TD></TR><TR><TD CLASS="quote">that calls for a new control arm, if the bolt doesnt come out </TD></TR></TABLE>
Read very carefully, the bolt never comes out when the bolt is seized to the inner can of the bushing. This page details the removal of the old bushing if the bolt is seized in the inner can of the bushing, here's a recap:
1) Cut the bolt between the shock fork and the control arm, 2 places.
2) Remove the shock and you're left with the shaft of the bolt stuck in the inner can of the bushing. You can try to drill out the bolt but I doubt you can do it cleanly.
3) Now get out your torch and burn the bushing untill the inner can be removed. I find it better to just heat the inner can till the opposite side starts to smoke. Pull the torch off and get your vice grips out and pull the inner can out.
4) Now you're left with the outer can of the bushing (pressed into the control arm) and some rubber stuck to the inner diameter.
5) Get your hacksaw and insert it through the hole in the bushing and cut through the outer can in 2 places... don't cut through the control arm. The outer can will then pop out.
6) Now insert your new bushing of choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Replacing rear lower control arm bushing:
Remove LCA from vehicle.</TD></TR></TABLE>
Sometime the outer bushing (closest to the wheel) is also seized. I left the control arm on the car and did the procedure like the TI page. Pain to do under the car. After you do a couple of integras it goes pretty quickly.
Old Jun 8, 2006 | 04:16 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
clearly explained!
turbotime
May 3, 2007 09:49 PM
sohc_student
Suspension & Brakes
Sep 4, 2006 11:05 PM
TheHatchHog
10
Jul 29, 2004 07:15 AM
94CivicSi
Mar 24, 2002 05:21 PM
integra0260
Jul 16, 2001 12:32 PM
