how is the stock headunit mounted in a 96-98?
Old Jun 4, 2006 | 08:52 AM
ekcivic9's Avatar
Default how is the stock headunit mounted in a 96-98?
hey guys
sorry i know this isnt really "technical" but replies come wayy faster than it does in the a/v section.
yesterday i restored my old factory headunit into its spot, i got tired of the aftermarket headunit look, and the stock one flows much better with the interior.
however, since installing my headunit last summer, i dont remember if there is supposed to be any mounting places to screw a screw into the headunit to keep it in place... right now its just sitting there and ocasionally pops out.
any ideas?
thanks
Old Jun 4, 2006 | 09:02 AM
G2 Speed's Avatar
Default Re: how is the stock headunit mounted in a 96-98? (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys
any ideas?
thanks</TD></TR></TABLE>
I belive there are screws.... pull off the panel with the accesory jack, don't know what the whole panel is called, and I belive you screw upwards.. if you know what i'm saying...
Old Jun 4, 2006 | 09:08 AM
ekcivic9's Avatar
thanks g2, ill go look into it when i feel like ripping everything apart again till now, ill just push it in every so often
Old Jun 4, 2006 | 10:16 AM
G2 Speed's Avatar
Default Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">thanks g2, ill go look into it when i feel like ripping everything apart again till now, ill just push it in every so often </TD></TR></TABLE>
I'm pretty sure!!.. I'm not guaranting that it's there but I do know it screws in. it could either be at the side.. or below...
GL
Old Jun 4, 2006 | 10:25 AM
igo4bmx's Avatar
screws are usually on the side.
Old Jun 4, 2006 | 11:59 AM
SPD DMN's Avatar
I do this all the time, the 2 screws that hold the headunit in place needs to screw into the bottom of the head unit. When you slide the head unit into the metal frame, there are 2 holes for u to screw into the frame and into the headunit to secure its position.
Good luck!
Old Jun 4, 2006 | 12:27 PM
G2 Speed's Avatar
Default Re: how is the stock headunit mounted in a 96-98? (SPD DMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPD DMN &raquo;</TD></TR><TR><TD CLASS="quote">I do this all the time, the 2 screws that hold the headunit in place needs to screw into the bottom of the head unit. When you slide the head unit into the metal frame, there are 2 holes for u to screw into the frame and into the headunit to secure its position.
Good luck!
yay i was right!!
Old Jun 5, 2006 | 11:34 AM
SPD DMN's Avatar
Default Re: how is the stock headunit mounted in a 96-98? (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">
yay i was right!!</TD></TR></TABLE>
No I was right
Old Jun 5, 2006 | 05:48 PM
slowEM1's Avatar
http://www.handa-accessories.c...o.pdf
Old Jun 5, 2006 | 10:13 PM
SPD DMN's Avatar
Default Re: (slowEKcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowEKcoupe &raquo;</TD></TR><TR><TD CLASS="quote">http://www.handa-accessories.c...o.pdf</TD></TR></TABLE>
hmm... that doesnt look like the right dash for his 96-98 civic... heres the link I used, everything was 100% accurate and easy
http://www.installdr.com/Insta...3.pdf
This should clarify everything you need to ask
GL
pvt_awol
May 10, 2007 11:08 AM
Extreez
Jul 31, 2006 06:15 AM
Newborn_
Honda Civic (2001 - 2005)
10
Jun 23, 2006 04:42 AM
RSXisS
Feb 18, 2005 07:04 AM
BlueFang08
Jan 12, 2005 01:41 PM
