help..axle problem
Old Jun 4, 2006 | 07:32 AM
HB VTEC's Avatar
Default help..axle problem
i have a 94 honda civic, and put a d16z6 in it..the driver side axle will not go all the way in the tranny and is leaking oil when driving it..the passenger side is fine but the driver side is off buy a mm..any suggestions...thanks
Old Jun 4, 2006 | 09:14 AM
Slamaccord's Avatar
Default Re: help..axle problem (electronbluehatch)
Make sure its in all the way. I normally use the plunger technique.
Try replacing the c- clip.
Last but not least are you using the right axle ?
Old Jun 4, 2006 | 10:40 AM
HB VTEC's Avatar
yes i am using the correct axle...it doesn't go in all the way..maybe i need to do the c clip...thanks
Joe...
Dec 29, 2006 06:54 PM
ALLINWONDER
Jan 17, 2006 06:00 AM
BoRiCuA
Jan 1, 2006 03:18 PM
Aphelion
Apr 25, 2005 04:18 PM
Jer'rome
Sep 30, 2004 06:14 PM
