no speedo
Old Jun 4, 2006 | 06:19 AM
rdssk8rcs1's Avatar
Default no speedo
i just finished a tranny swap in my 93 da everything runs and works perfectly exept for teh speedo
it doesnt work at all?
any ideas of what could have happened?
Old Jun 4, 2006 | 06:27 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: no speedo (rdssk8rcs1)
Check the speedometer cable. Make sure it is engaging with the speedometer gear.
Old Jun 4, 2006 | 09:08 AM
Rhythmsnewsn's Avatar
Default Re: no speedo (Dogginator)
yeah also check if its pluged into the tranny correctly. the same thing happened to me once.
Old Jun 4, 2006 | 10:41 AM
rdssk8rcs1's Avatar
Default Re: no speedo (Rhythmsnewsn)
i check that
is there a special way the cable has to go in?
there isnt a specific notch that the cable has to go in is there?
how would i check if its plugged into the tranny right?
i did replace that because for some reason the one on the new tranny was broked and ghettoed onw ith zipties because the bracket broke,but i replaced it while it was off the tranny and it bolted in fine
Old Jun 4, 2006 | 09:41 PM
RHDintegXsi's Avatar
i would say its probably the spedometer cable..either at the tranny or behind the cluster..usually you'll have a check engine light also
Old Jun 5, 2006 | 04:12 PM
rdssk8rcs1's Avatar
Default Re: no speedo (SINFULintegXsi)
yeah thats what i was thinking and because i just disconnected it from the tranny during th eswap i guessed it happened rthen
is there a special way to connect the cable inside the sensor?
MANDO6669
Jun 7, 2006 09:19 PM
saver
Apr 25, 2006 08:30 AM
You Know I Got SOL!
Aug 22, 2005 12:43 PM
gsrvx
Feb 5, 2005 07:41 PM
