oil pressure question
Old Jun 4, 2006 | 05:40 AM
brusk13's Avatar
Default oil pressure question
After I had my engine rebuilt the oil pressure seems alot higher than I would expect. I didn't install the oil pressure guage untill after the engine went in. I'm running about 75PSI most of the time when the engine is hot. Idle is still about 30. And when it's cold it will get to about 105. I'm worried that maybe they used too big main bearings. Would this cause this to happen? Is the stock pressure sending unit located between the oil pump and main bearing? I'm concerned the head might not be getting enough oil pressure if this is the case.
Preludepradit
Oct 12, 2007 01:57 PM
Soccerking3000
May 10, 2005 11:39 AM
boosted k20
Feb 16, 2005 08:29 AM
GTEater
Jan 1, 2002 07:36 PM
