chipped socketed ecu questions
Old Jun 3, 2006 | 10:08 PM
CBEengineering's Avatar
Default chipped socketed ecu questions
I need info/ links with explanations of what to do to an ecu to tune it. Im kinda new to the whole ECU thing. mostly motor swaps and P+P ecus like gsr with gsr or b16 with p30 but....my dad just purchased a 93 civic si hatch and we are in the process of installing a jdm 96 spec itr engine.. it came with the ecu(p73) but i really dont want to jump to OBDII so id like to use the p28 or a p30 i have in the shop and have it tuneable. the car is immediately getting the I/H/E treatment but might see some cams and other stuff later on in its life so I would like the tuneability.....In a nut shell im a hands on kinda guy and I really like to know how things work so any explanations/links/info will help
plus my car (95 civic ex coupe b16 ITRcams-mani) needs a tune also so this will benifit me too (oh and for the 92-00 civic forum i dont care if you think it doesnt belong here i posted it in three forums for maximum coverage)
Old Jun 3, 2006 | 10:20 PM
IVAN93EG's Avatar
Default Re: chipped socketed ecu questions (CBEengineering)
go to pgmfi.org and you will learn all you need to know. good luck
Old Jun 3, 2006 | 10:22 PM
daliumong's Avatar
pgmfi.org
so basically you need a conversion harnace
obd2->obd1
then you can use a p28 ecu chipped with the itr maps
to chip it you basically need a 28 pin socket, some capacitors, one other thing i forgot what its called and a 28 pin amtel chip and a HC373 chip
Old Jun 4, 2006 | 07:38 AM
Default Re: chipped socketed ecu questions (daliumong)
ok thanks
bytheway both vehicles i listed were obd1 to begin with so no conversion harnesses
Old Jun 4, 2006 | 09:05 AM
Slamaccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daliumong &raquo;</TD></TR><TR><TD CLASS="quote">pgmfi.org</TD></TR></TABLE>\
Read lots and lots.
CBEengineering
Jun 4, 2006 07:36 AM
IGotVTECyo
Sep 4, 2005 08:46 AM
VtecbOi
Mar 30, 2003 07:06 PM
311
Jun 12, 2002 03:21 PM
