ls vtec swap, no start
Old Jun 3, 2006 | 12:32 PM
GsrTurboCRX88's Avatar
Default ls vtec swap, no start
I just swapped an ls vtec motor in my crx and I can't get it to start.
I'm have spark
fuel
compression
checked the timing several times
Also, i am wondering if my timing belt is too long. It seams kind of loose on the exhaust side. it is a gsr belt and i got a gsr head.
Old Jun 3, 2006 | 12:34 PM
Default Re: ls vtec swap, no start (GsrTurboCRX88)
if the timing belt was too loose would that cause it not to start?
Old Jun 3, 2006 | 01:24 PM
any thoughts?
Old Jun 3, 2006 | 01:36 PM
blumpfish's Avatar
this might sound stupid but check the distributer wires, and make sure their in the right order. i did a compression test a few weeks ago and felt pretty stupid after i found out thats why i couldnt start up.
thats the only thing i can think of off the top of my head, im not too mechanically inclined.
Old Jun 3, 2006 | 01:44 PM
Default Re: ls vtec swap, no start (blumpfish)
thanks for your input. any other ideas?
Old Jun 3, 2006 | 01:47 PM
SIXTY's Avatar
What kind of water pump, you need gsr or type-r water pump to run the gsr belt. If you have an ls water pump you need to run the ls timing belt. Good luck.
Old Jun 3, 2006 | 02:23 PM
Default Re: ls vtec swap, no start (sixty-seven point six)
it's a gsr water pump
Old Jun 5, 2006 | 07:36 AM
I figured it out. the guy at auto zone must have sold me the wrong pump. So i went with an ls timing belt and re timed it and it started right away
Old Jun 5, 2006 | 07:44 AM
ludesrv's Avatar
Good to know it's fixed. I was gonna guess a blown coil or ignitor as the next shot as to why it won't catch.
B18B1-Crx
Jun 18, 2011 07:59 PM
turbo_b16_ex
Oct 4, 2005 11:06 AM
lsvtechatch04
May 8, 2004 03:20 AM
JR Integra
May 3, 2004 04:17 PM
spettinger
Feb 1, 2003 12:49 PM
