cant get code for obd0 to obd1 conversion. please help!!!
i put an obd1 b16 in my ef and the check engine light is on. i don't know where to put my jumper in to check the code. i used a jhp jumper harness and they said that it is on there but he couldn't tell me exactly where to put it. car does run rough and doesnt want to start the first 2 times i turn the key. vacuum is fine. i think it may have something to do with the o2 sensor warmer or what ever it is. PLEASE HELP!!!!!!!!!!!
tougetuned_ef@yahoo.com
There is a little plug all by itself, in the engine compartment. In front of the driver's side shock tower by the motor mount. It is coming out of the harness that runs to the headlight etc. It is one plug with two wires. Just jump the two wires. If you cant find i will post a pic.
thanks the helped alot now i know i have a nice wiring problem in my dizzy. hey la quiete, the harness has a rubber cap on it you cant miss it. its the only harness on the driver side right above your driver side mount.
Modified by tougetuned_ef at 9:33 PM 6/10/2006
dem0nk1d
32
Sep 15, 2007 11:49 PM
SuicideSlide
Nov 4, 2004 03:31 PM
