fs: fully built lsvtec turbo gt35r hks bov
i have a fully built ls vtec turbo up for sale. but the bottem need to be assemble.
head: complete gsr head
stage 2 port and pollish
crower dual valve spring
crower titanium retainer
rev stainless steel valves
blonze valve guild
3 angle valve job
venom manifold
310 rc injector
adjustable fuel pressure regulator
gsr cams
skunk 2 adjustable cams gears
block: ls block
the block is not assemble
ls eagle h-beam rods
wisco pistons coated
ls crank
ls flywheel
act 4 puck stage 6 clutch
arp rod bolts
block guard
timing belt
type r oil pump
gsr water pump
mis part: msd ignition (external coil blaster, msd spark plug wire msd box)
golden eagle ls vtec kit
all neccessary gasket for the bottom bloc
p28 ecu
wiring harness
turbo:
gt35r ball bearing turbo
(cold .72 a/r hot .82)
big fmic no bent finn
2.5in intercooler piping mandrel bent
khs bovs
tobonetics wastegate
vortec fmu
equal length manifold
3in downpipe
all this parts are completely brand new. excluding the head. the head have been use around 1k miles
bottom end parts and turbo parts are all brand new in box.
if you are interested then feel free to give me a call at 505 620-3344
for those who are interested then make me a reasonerable offer.
let me know ifyou want some pic
blonze valve guild
3 angle valve job
venom manifold
310 rc injector
gsr cams
block: ls block
ls crank
ls flywheel
arp rod bolts
block guard
timing belt
type r oil pump
gsr water pump
p28 ecu
wiring harness
turbo:
khs bovs
vortec fmu
3in downpipe
BLKTeg94
Sep 7, 2009 01:45 PM
