civic cx boggs under WOT
Old Jun 2, 2006 | 06:58 PM
wshondaman's Avatar
Default civic cx boggs under WOT
i have a stock civic cx that i bought with a blown motor in it. i recently put a used motor in and it statrts a idles perfectly. the problem is once i get over 1/4 throttle it just boggs it won't go naywhere. i have already checked timing and marks are on the money. map sensor voltage output is where it should be. i am not sure where else to go, any help would be greatly appreciated.
thanks
Old Jun 2, 2006 | 07:46 PM
Civicse's Avatar
Default Re: civic cx boggs under WOT (wshondaman)
are you throwing any codes? check tps and o2 sensors
Old Jun 2, 2006 | 08:30 PM
FalkenSiR's Avatar
Switch your MAP sensor and your TPS sensor and tell me what happens. Takes 20 seconds
Old Jun 2, 2006 | 10:52 PM
EK79's Avatar
double check injectors could be a fuel problem
futurefastguy
Sep 14, 2006 02:54 PM
djrock04
Dec 31, 2005 01:38 PM
kechup2eg6
Aug 10, 2005 07:47 PM
roninb18
Jan 16, 2003 10:30 AM
RuffRhyno
Aug 29, 2002 07:00 PM
