Need Help With Removing Dashboard For 96 Civic EX
Hey guys,
I am removing all the parts from a 96 civic ex and trying to put them in a 97 ek. I really need help removing the dash in the 96 ex...... I have unscrewed all the bolts and screws i can *get* too. There are some such that i can't see how to get them. If you can help pease reply, i can give you move description. Thanks for the help.
Honda_Modifier
Honda_Modifier
first take out garnish on top of dashboard right in the middle, take out bolt.
then you have one on the outside on the drivers side
then you have two on the passenger side (the dashboard is kinda hung in there in the brackets)
you also have two on the drivers side inside facing the a pillar.
the you have two in the back of the steering rack and two nuts in the front. also one single bolt on the right hand of the steering rack in the back
also you need to loosen the connection to the floor underneath the center console. make sure to disconnect all harnesses from the fuse box and the dasboard wiring from the main harness. also don't forget to unhook antenna.
BADFISH707
May 27, 2009 11:54 AM
one8toh8
11
Feb 28, 2008 03:12 PM
Honda_Modifier
Jun 2, 2006 06:56 PM
