Some Nitrous Questions for my CRX.
Old Jun 2, 2006 | 03:23 PM
AudioXtremes's Avatar
Default Some Nitrous Questions for my CRX.
Ok, I have a ZC motor in my 89 CRX and a 15.4 with a 2.4 60ft just sucks. So... I'm ordering slicks and a N2O kit. Just wanting to make sure I know everything I need to do. I will be starting out with 50 and moving to 75 shot.
Colder spark plugs. KGK # 3330
Retard timing 3-4deg
Increase fuel pressure.
I also have some Prelude 325 or 345cc injectors I may run to make sure there is enough fuel.
Also what size slicks should I run? I can get 20, 22, or 24.5".
Old Jun 2, 2006 | 05:10 PM
STREETWERKZ's Avatar
Default Re: Some Nitrous Questions for my CRX. (AudioXtremes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioXtremes &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I have a ZC motor in my 89 CRX and a 15.4 with a 2.4 60ft just sucks. So... I'm ordering slicks and a N2O kit. Just wanting to make sure I know everything I need to do. I will be starting out with 50 and moving to 75 shot.
Also what size slicks should I run? I can get 20, 22, or 24.5".</TD></TR></TABLE>
20 inch slicks will be fine..... even if you spray out of the hole on the 75 shot.
prelude injectors really arent needed, unless you have the ecu capabilities to scale them down a little.
what sort of kit are you buying? dry kit? single fogger wet? direct port?
i ran a direct port 100 shot on a B16 and loved it...
all other experience i had with nitrous before that were only 50 shot dry kits, which honestly are a joke when youre trying to make power.
AudioXtremes
Jun 2, 2006 05:01 PM
Greenery18
Jul 27, 2004 09:33 PM
OneFastGsr
Sep 13, 2003 09:22 PM
-=TWITCH=-
10
Jun 28, 2002 07:31 AM
-=TWITCH=-
May 27, 2002 05:11 PM
