Some general Nitrous questions
Ok, I have a ZC motor in my 89 CRX and a 15.4 with a 2.4 60ft just sucks. So... I'm ordering slicks and a N2O kit. Just wanting to make sure I know everything I need to do. I will be starting out with 50 and moving to 75 shot.
Colder spark plugs. KGK # 3330
Retard timing 3-4deg
Increase fuel pressure.
I also have some Prelude 325 or 345cc injectors I may run to make sure there is enough fuel.
Also what size slicks should I run? I can get 20, 22, or 24.5".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx »</TD></TR><TR><TD CLASS="quote">lean is rarely the prob, timing is everything. to much retard can be bad just as not enough.</TD></TR></TABLE>
So do you think 4deg is too much for a 75 wet shot?
Also are the NGK 3330 plugs good ones to run?
Use a wet kit so no additional fuel is necessary at the injectors. I would run 16 degrees base timing w/ a 50 shot, and would not retard timing more than 2 degrees w/ a 75 shot. Run NGK 7's gapped around 30, and make sure everything else on your motor is up to snuff. A high flow fuel pump is a very good idea if you don't have one already.
AudioXtremes
Jun 2, 2006 05:10 PM
