bledding brakes
Old Jun 2, 2006 | 12:41 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Default bledding brakes
I have a quick quetion to ask. How to i bleed the mc? thanks
Old Jun 2, 2006 | 01:01 PM
instructor74's Avatar
Default Re: bledding brakes (phyz)
things you will need 1 a friend to help, 2 an assortment of wrenches, 3 empty. clear bottle, 4 a few bottles of dot 3 brake fluid
jack the car up put it on stands and remove all 4 wheels. get a piece of clear tubing and a clean clear bottle (empty soda bottle will work) put about 1/2 inch of clean brake fluid in the bottle. Go-to the RR brake cal there will be a small bleeder nipple on the cal. put 1 end of the tubing over the end of the nipple(tubing should fit tight on nipple)submerge the other end in the clear bottle. STEP 1 Have your friend get in the car and pump the brake until it is hard and hold pressure on the pedal.STEP 2 Crack open the bleeder. have friend tell you when the pedal is on the floor.STEP 3 close the bleeder and repeat steps 1-3 until only clear fluid comes out with no air bubbles.(see the reason for the clear bottle and line). repeat for all breaks in this order RR LF LR RF. Read your shop manual with any other questions . Make sure that you top of the mc every few bleeds you do to keep air out of the system good luck
Old Jun 2, 2006 | 01:11 PM
thanks for the instructions
Old Jun 2, 2006 | 01:35 PM
AutoXer's Avatar
Default Re: (phyz)
Do you want to bleed the brakes or the master cylinder? The instructions above were for the brakes. You can also do it yourself if you use a setup like this:
No air will get back into the lines as long as the tube is submerged.
Old Jun 2, 2006 | 01:38 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
I nominate this for the best use of MS Paint this year
Old Jun 2, 2006 | 02:26 PM
AutoXer's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
I nominate this for the best use of MS Paint this year </TD></TR></TABLE>
*waves hand*
Thank you, thank you... I do it for the kids, folks.
Old Jun 2, 2006 | 02:47 PM
postman's Avatar
to bleed mastercylinder, loop the outlet lines back to the resevoir and push in the master cylinder a couple of times.
Old Jun 2, 2006 | 11:35 PM
thanks alot guys
Old Jun 2, 2006 | 11:37 PM
Hay autoXer wanna make me a diagram of bleeding the mc?
M.C paint is the ****!
creator1322
12
Jun 6, 2010 04:08 AM
henni
Aug 15, 2009 03:56 PM
Accord2001
Oct 2, 2005 06:15 PM
Silvteg95
Aug 19, 2005 10:50 PM
tremor86
Dec 1, 2003 05:24 AM
