Tachmeter
Alright I have another problem i bought a FAZE tach and i hooked everything up but i cant find the negative wire to the ignition coil so my tach lights up but my rpms arent workin so can someone either tell me where it is or how to do it or something but i have a 90 ef sedan
ok so its the blue wire coming directly out of the distrubitor right cause there is a blue and a black wire but last night when i touched them together the rpm on the tach didnt move
yes first 2 switches on left - up is "ON" - did your car have OEM tach? if so, you may need to disconnect the blue tach wire from the cluster - not sure, never installed Faze
is u take the cover off your cluster you should see a blue wire running into it. This is the tach signal wire. Tap into that and there you go. You don't have to run a wire into your firewall. If you still need help let me know and i can link you to a thread
Tyson
40
Jun 4, 2009 04:24 PM
