how much oil should be used for a d16 ?
Old Jun 2, 2006 | 09:14 AM
Hatchless96's Avatar
Default how much oil should be used for a d16 ?
I have a civic ex coupe stock engine. How much oil should i pore in there when i change my oil?
Old Jun 2, 2006 | 09:29 AM
G2 Speed's Avatar
Default Re: how much oil should be used for a d16 ? (Hatchless96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchless96 &raquo;</TD></TR><TR><TD CLASS="quote">I have a civic ex coupe stock engine. How much oil should i pore in there when i change my oil?</TD></TR></TABLE>
search man... and if your to lazy
ex coupes don't take oil **** in it
Old Jun 2, 2006 | 09:46 AM
JShull's Avatar
3.5 minus the filter so around 4 with it.
Old Jun 2, 2006 | 10:06 AM
EK79's Avatar
3.8 quarts
Old Jun 2, 2006 | 11:01 AM
fmrprojects's Avatar
Default Re: how much oil should be used for a d16 ? (stoopid monkey)
put in 3.5 quarts then check the oil and see if its enough and add more if neccessary
Old Jun 2, 2006 | 12:21 PM
asgqwaeg's Avatar
around 3.8-4.0 is how much oil I usually put in when I change mine.
Old Jun 2, 2006 | 01:07 PM
Archidictus's Avatar
Unceasing Measure
Default Re: how much oil should be used for a d16 ? (JdmEk96)
My Z6 takes 3.4, so don't be telling this guy to overfill it. Start with 3ish quarts, run the engine for 10 seconds or so, turn it off and check the level. Add more accordingly.
Old Jun 2, 2006 | 01:12 PM
2DoorBandit's Avatar
Default Re: how much oil should be used for a d16 ? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">My Z6 takes 3.4, so don't be telling this guy to overfill it. Start with 3ish quarts, run the engine for 10 seconds or so, turn it off and check the level. Add more accordingly.</TD></TR></TABLE>
3.8 straight out of my Haynes manual
Old Jun 2, 2006 | 01:14 PM
Unceasing Measure
Default Re: how much oil should be used for a d16 ? (2DoorBandit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DoorBandit &raquo;</TD></TR><TR><TD CLASS="quote">3.8 straight out of my Haynes manual</TD></TR></TABLE>
3.4 straight from being a professional mechanic with the engine in question
Putting 3.8 quarts in there won't hurt anything, especially since I think he has a Y8 and not a Z6, but it's always better to start with less and add more than deal with an overfull crankcase
Old Jun 2, 2006 | 01:22 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">3.4 straight from being a professional mechanic with the engine in question </TD></TR></TABLE>
Manual &gt; person
My D16A6 takes 3.7 quarts with a filter change, staight out of the 1991 Honda CRX Owner's Manual and the Helms FSM. I doubt the Z6/Y8 takes less.
Besides, the exact number isn't important - what is important is that the oil level in the sump is at the top hole on the dipstick, not above or below.
Old Jun 2, 2006 | 01:28 PM
GuateskateVti's Avatar
Default Re: how much oil should be used for a d16 ? (Targa250R)
3.8 quarts
Old Jun 2, 2006 | 01:30 PM
Unceasing Measure
Helms, 92-95 Civic, D16Z6 specs
Old Jun 2, 2006 | 01:40 PM
Helms, 92-95 Civic, D16Z6 specs </TD></TR></TABLE>
3.3 is liters 3.5 is U.S quarts 2.9 is lmp Quarts
Old Jun 2, 2006 | 01:41 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DoorBandit &raquo;</TD></TR><TR><TD CLASS="quote">3.3 is liters 3.5 is U.S quarts 2.9 is lmp Quarts</TD></TR></TABLE>
Yessir. I said 3.4 quarts earlier: must have been off by a tenth
Old Jun 2, 2006 | 02:25 PM
addiction2bass's Avatar
i never know how much oil a car takes.. what i do...... get 6cans of oil fill up the filter depending on th instal angle how much you can add with out it all pouring out when instaling then fill up the oil to the dip sticks oil line........ start the motor up for a min, turn it off and continue to fill it to the oil line. always worked for me :D
Old Jun 5, 2006 | 09:45 AM
Targa250R's Avatar
be professional
Default Re: how much oil should be used for a d16 ? (justchilling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justchilling &raquo;</TD></TR><TR><TD CLASS="quote">that aint a z6... my **** says 3.8.</TD></TR></TABLE>
My '92 Civic Helm manual is showing the exact same specifications as in that picture. What manual are you getting 3.8 from?
Old Jun 5, 2006 | 10:02 AM
PSU's Avatar
PSU
formerly DxHatchback
i've always run with 3.5 quarts and my car is still going strong
Old Jun 5, 2006 | 10:06 AM
Unceasing Measure
Unless this English major can't read, yessir, it is.
Old Jun 5, 2006 | 10:10 AM
Soccerking3000's Avatar
lol you guys got owned
ahron
Sep 9, 2007 06:59 PM
tilhasbb
Honda Civic (2006 - 2015)
24
May 28, 2007 12:11 PM
Y2A
Nov 17, 2004 05:31 AM
AsnRefugee
10
Mar 7, 2004 10:23 PM
Al Czervik
Jun 10, 2003 01:29 PM
