compression results gsr
Old Jun 2, 2006 | 08:38 AM
wildercard's Avatar
Default compression results gsr
picking up a gsr and going to run a compression test on motor, question what figures should i be expecting. i know the b16 figs but not the gsr any help is appreciated.
Old Jun 2, 2006 | 08:45 AM
SoEvoL's Avatar
Default Re: compression results gsr (wildercard)
what your looking for are numbers that are in the same range. i think they are 160+ for a gsr, i dont know exactly someone can chime on that. but you want something like
180 179 183 185 for example
something like 90 180 200 132 would be bad
hence numbers in the same range....
good luck mate
Old Jun 2, 2006 | 08:52 AM
yee SERIOUS's Avatar
at least 190 imo. 185 is ok, but i wouldn't give it a passing grade.
my 2000 gsr read 235 straight across, even after being turbo'd for 9 months.
i think 10:1 is 200-235psi and 9:1 is 185-200psi....something like that.
Old Jun 2, 2006 | 08:58 AM
wildercard's Avatar
Default Re: (undercoverdc2)
the b16 is about 185 so i definitely expect something higher then that for the gsr....... anyone know the exact figure, if not ill look for something around 225 to 235 .. thanks for the info guys
Old Jun 2, 2006 | 09:15 AM
wildercard's Avatar
Default Re: (wildercard)
Found out this info: for both the b8c1 and c5 the standard is 270 psi with a min of 135 and apparently with a max variation of 28 psi btw cylinders. This is info is confirmed by two separate sources. More info can be found at one of the sources: http://www.team-integra.net/se...=1086
Old Jun 2, 2006 | 09:53 AM
Sam92Teg's Avatar
Wow, that's high. According to the Helms :
The b17a1 Nominal 184, Min 134 Var 28 I don't have the specs on the B18c.
b18a1 Nominal 185, Min 135 Var 28
Surprising that the b18c's compression would be that high, but they do have higher static compression. I am stumped that the low (9.2) compression on the b18a1 yeilds higher compression numbers than the b17a1.
Old Jun 2, 2006 | 11:15 AM
SoEvoL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildercard &raquo;</TD></TR><TR><TD CLASS="quote">Found out this info: for both the b8c1 and c5 the standard is 270 psi with a min of 135 and apparently with a max variation of 28 psi btw cylinders. This is info is confirmed by two separate sources. More info can be found at one of the sources: http://www.team-integra.net/se...=1086</TD></TR></TABLE>
just make sure the variation isnt off horribly
Old Jun 2, 2006 | 11:57 AM
wildercard's Avatar
Default Re: (SoEvoL)
Yeah if the variation is off to much i will not take it. What i am surprised about is that the c1 and c5 are the same, i would have thought that the c5 would be higher.....good info nevertheless, perhaps the figures for all these motors should be added to the FAQ
hawaiieg6
Jul 15, 2009 08:57 AM
brent_si
Dec 12, 2008 05:41 AM
hatch96y7
Jul 1, 2007 05:03 PM
bustdgst
Jan 25, 2007 09:54 PM
