Is there any hope left for my motor Picture inside
Old Jun 2, 2006 | 07:49 AM
teler86's Avatar
Default Is there any hope left for my motor Picture inside
so i just swapped in a p30 b16 into my crx, it took me 10 months to get it running perfect, while going to school and working full time, and now this happens. Yesterday was the first day i had my car out and running perfect for the first day and then while i am on the freeway i think i hear a knocking sound but am not sure so i open up my windows and listen, then all of the sudden my cabbin starts filling with smoke and the oil light comes on, i turn my car off and have it towed, when i get home i see that my oil pan gasket is busted and it was seeping oil onto the the exhaust manifold. I took off my oil drian plug bolt and saw this!!!
The oil pan still had about 2 quarts worth of oil left in it, do you think there is any hope left for my motor, or does it needs a rebuild, also i saw metal shavings in the oil runners down from the head, is there any way i can get them out
Old Jun 2, 2006 | 08:12 AM
trickeng's Avatar
Default Re: Is there any hope left for my motor Picture inside (teler86)
the material is magnetic so its something very serious and if the oil pan is now damaged to the point where oil is blowwing out of it i say you my have broken a connecting rod.
drop the oil pan and report back. yes there is still a chance you can salvage something from the motor.
Old Jun 2, 2006 | 11:17 AM
teler86's Avatar
well, i poped off the oil pan and and the rod in cylinder number 4 felt loose, could it only be the rod bearing or did i expletive up the crankshaft as well
Old Jun 2, 2006 | 11:18 AM
trickeng's Avatar
Default Re: (teler86)
your crank is most likely junk.
Old Jun 2, 2006 | 11:46 AM
96Spec Ek's Avatar
If you spin a rod bearing in the crank is junk.
Old Jun 2, 2006 | 12:04 PM
teler86's Avatar
is there any way to check the crank, i have to pull the motor again dont I???
Old Jun 2, 2006 | 06:06 PM
teler86's Avatar
anybody???
Old Jun 2, 2006 | 06:31 PM
Runnerdown's Avatar
its shot, you are better off just gettting a replacement longblock.
Old Jun 2, 2006 | 06:58 PM
teler86's Avatar
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">its shot, you are better off just gettting a replacement longblock. </TD></TR></TABLE>
not what i wanted to hear but better than me just replacing parts for no reason
Old Jun 2, 2006 | 07:00 PM
teler86's Avatar
do you think the head is good???
Old Jun 2, 2006 | 07:05 PM
Runnerdown's Avatar
depends on how oil starved it got. Really at this point only a full teardown with a knowledgable eye will know for sure.
Old Jun 2, 2006 | 07:34 PM
HondaCivicSiR1's Avatar
pm'd
EM2_PLo
Honda Civic (2001 - 2005)
May 6, 2010 01:34 PM
SIMSSEGA
Nov 25, 2008 09:45 AM
IntegraType-R
25
Nov 5, 2007 04:58 PM
SIMSSEGA
Apr 2, 2006 11:04 PM
Charlie Moua
May 14, 2003 07:04 AM
