B16 Hesitation Please Help
Old Jun 2, 2006 | 04:16 AM
NA_DA's Avatar
Default B16 Hesitation Please Help
Thanks for taking the time to look at this. I have a OB0 B16 in my Crx. Around 6k it falls flat on its face. I was getting the secondary 02 sensor code so I swithced the sensors around and the code stopped. My friend and I played with the ignition timing and got it to go to 7k. It feels like its not getting enough fuel. Sort of like running into a rev limiter but its not. My friend checked vaccuum lines and said that the main ones are fine. I do know the IACV isnt hooked up but I doubt that would have an effect on vtec crossing over. Another theory is that the wire i have isnt getting enough voltage to get the vtec solenoid going. If you have an insight as to what I should check please let me know. My ecu is a PWO. Cant get my picture to come up
Modified by NA_DA at 5:26 AM 6/2/2006
Old Jun 2, 2006 | 10:24 AM
NA_DA's Avatar
Default Re: B16 Hesitation Please Help (NA_DA)
Bump! Throwing code 17 VSS. I havent touched it WTF! Swap Gurus please help my ignorant *** out.
Old Jun 2, 2006 | 10:27 AM
.Manny.'s Avatar
Touching My Member
im amost sure that the vtec wont cross over if the vss isnt up to par.
fix that and drive it again, oh yeah reset the ecu too.
Old Jun 3, 2006 | 12:42 PM
NA_DA's Avatar
OK. Checked all vacuum lines to fuel pressure regulator and such. All three grounds are intact. Thermo to wiring harness, valve cover to frame, and the battery to transmission. Cleaned all the ground mounting points. Still falls flat on its face around 6 when vtec is supposed to engage. Do I have a bad vtec solenoid?
Old Jun 5, 2006 | 08:24 PM
NA_DA's Avatar
Bump. Completely rewired vtec. No other check engine lights except the VSS how can I correct this. Is it the reason my vtec bogs down?
Old Jun 5, 2006 | 08:53 PM
downest's Avatar
Default Re: B16 Hesitation Please Help (90_EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">im amost sure that the vtec wont cross over if the vss isnt up to par.
fix that and drive it again, oh yeah reset the ecu too. </TD></TR></TABLE>
True story.
Old Jun 6, 2006 | 06:38 AM
crx_88_si's Avatar
vtec will not engage unless the VSS code is fixed. 6k-7k is just where the low cam runs outta steam.
Old Jun 6, 2006 | 07:03 AM
si90rex's Avatar
Default Re: (crx_88_si)
wont the motor still rev to 7500 even if vtec doesn't work. i know a sohc will. so i don't think its got to do with the vtec. i think theres some thing else wrong here.
blasterman87
Sep 16, 2009 02:34 PM
Ran4it2
Aug 17, 2009 11:53 AM
wdbdycrx
Mar 13, 2005 06:21 PM
TRhatchCRAP
Aug 1, 2003 05:40 PM
HarryB
Jul 11, 2003 11:44 AM
