04-05 tl hid retrofit in stock headlights?
Old Jun 2, 2006 | 12:57 AM
vladd's Avatar
Default 04-05 tl hid retrofit in stock headlights?
Is it even possible to put the 04-05 TL hid projectors/hids in stock 98 headlights? i can get the projectors with bulbs and the ignitor box. what else would be needed?
Old Jun 2, 2006 | 02:30 PM
vladd's Avatar
Default Re: 04-05 tl hid retrofit in stock headlights? (civicdxtyper)
anybody?
Old Jun 2, 2006 | 04:25 PM
Options's Avatar
All Secrets Known
Here's a pretty good how-to.
Click here to check it out....
Old Jun 2, 2006 | 04:33 PM
vladd's Avatar
Default Re: 04-05 tl hid retrofit in stock headlights? (Options)
Yeah, I saw that one. I'm asking about the TL projectors though. That's from an Audi.
Old Jun 2, 2006 | 05:15 PM
Options's Avatar
All Secrets Known
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I saw that one. I'm asking about the TL projectors though. That's from an Audi.</TD></TR></TABLE>
You may want to look in these forums. A lot of good info here.
Click here....
Old Jun 2, 2006 | 06:29 PM
trickedvtec's Avatar
tl . audi its still the same thing you have to cut you stock projector off the bracket and modify to fit .. and yes it should work .. i got bmw 5 series in my 01 lights
Old Jun 2, 2006 | 08:14 PM
1turbodc2's Avatar
yes it will work u can hit up the guyz from customlightz, in my sign below to have them do it they did mine best customer service and great worksmenship!
Old Jun 2, 2006 | 08:59 PM
Danza's Avatar
Default Re: (1turbodc2)
It's possible, tough to do for a first retrofit because I believe they are bixenons.
Look for TSX projectors for a similar but easier retrofit
Old Jun 3, 2006 | 01:28 AM
vladd's Avatar
Default Re: (Danza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danza &raquo;</TD></TR><TR><TD CLASS="quote">It's possible, tough to do for a first retrofit because I believe they are bixenons.
Look for TSX projectors for a similar but easier retrofit</TD></TR></TABLE>
Why are bixenons harder? I'm new to this hid thing. The reason I'm asking about TL is because I might be able to get a set for pretty cheap. My friend has a set of cracked headlights that have good projectors in them.
Old Jun 3, 2006 | 02:11 AM
hobo_ken's Avatar
Default Re: (civicdxtyper)
Also the TL's are a 3" projector, so making them fit into the housing may be a little more difficult with the Integra housing having minimal space to work on.
Old Jun 3, 2006 | 08:33 AM
Danza's Avatar
Why are bixenons harder? I'm new to this hid thing. The reason I'm asking about TL is because I might be able to get a set for pretty cheap. My friend has a set of cracked headlights that have good projectors in them.</TD></TR></TABLE>
They're bigger
It's something else to wire if you want the bixenon feature.
Old Jun 4, 2006 | 04:04 PM
calxtreme's Avatar
You can probably get them to fit, i mean the term "retrofit" implies that there will be customization and creativity. Bi-xenon's projectors are usually bigger because they have the solenoid to pull back the cutoff shield.
honda94accord
Dec 1, 2007 08:37 AM
IntegraJdmb18c1
Feb 21, 2006 09:20 PM
NitroStickers
Sep 15, 2005 06:59 AM
Showtime_III
Feb 19, 2005 03:54 PM
B and B
Jul 26, 2003 10:12 PM
