Clutch problem
Old Jun 1, 2006 | 10:25 PM
faSHOwidIT's Avatar
Default Clutch problem
Ok here's the problem.....today the clutch engaging point got real high. before it would be in the middle now it's at the top. So what i did was re-bleed it and it was good for about 6hours, then it started to rise again. Also i know the clutch is wearing down, it only has 2000miles on it. It still grabs real good
Old Jun 1, 2006 | 10:50 PM
cao's Avatar
cao
check for leaks. slave/master cylinder.
Old Jun 1, 2006 | 10:52 PM
SOHC4life 96's Avatar
Default Re: (cao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cao &raquo;</TD></TR><TR><TD CLASS="quote">check for leaks. slave/master cylinder.</TD></TR></TABLE>
That's your problem. You have a leak somewhere.
Old Jun 1, 2006 | 11:16 PM
faSHOwidIT's Avatar
Default Re: (SOHC4life 96)
just checked for signs of leaking. nothing. Looked right underneath the dash, master cylinder and checked slaved cylinder. nothing. Can opening the cap and pumping the clutch put air in the system?
Old Jun 2, 2006 | 01:28 AM
faSHOwidIT's Avatar
Default Re: (faSHOwidIT)
worried
Old Jun 2, 2006 | 12:10 PM
faSHOwidIT's Avatar
Default Re: Clutch problem (faSHOwidIT)
ttt
Old Jun 2, 2006 | 12:25 PM
Dren's Avatar
Still sounds like a leak. Did you check the lines?
Old Jun 2, 2006 | 10:58 PM
cao's Avatar
cao
rebleed it make sure theres no air in it.
and just wondering how are you bleedin ur clutch.
Old Jun 4, 2006 | 01:15 AM
faSHOwidIT's Avatar
Default Re: (cao)
yes i double checked all the lines. i open up the needle and keep pumping the pedal until a stream of fluid comes out then shut the valve. i leave the cap off and keep filling when needed.
Old Jun 6, 2006 | 08:33 AM
trevor72's Avatar
Check the master cyl. nut on the adjusting rod. If it is loose, then spin the rod till you like the engagement height and then tighten the nut reall good. Mine came loose once after replacing the master cyl. because I didn't tighten it enough. Worth a look anyways.
Old Jun 6, 2006 | 08:53 AM
Kamin's Avatar
Default Re: (trevor72)
sounds like the master cylinder is going out.
zach1288
Jan 21, 2010 03:16 PM
vinceg143
Sep 9, 2008 07:14 AM
dartonh22
Jun 18, 2008 10:13 AM
TheAccordGuy
Nov 9, 2006 04:41 PM
94Accord2c
Apr 12, 2004 07:00 AM
