*SEARCHED* DA to EF Disc Swap Problem...
Old Jun 1, 2006 | 10:03 PM
Ls_dx's Avatar
Default *SEARCHED* DA to EF Disc Swap Problem...
i hooked up the torque compensators and sway bars, and the caster seems way off on the rears. the torque compensators are not in the same spot that they were in with the drums, so i am assuming this is why the alingment is hella off.... any insight would be appreciated...
Old Jun 1, 2006 | 10:15 PM
C uR eX's Avatar
Default Re: *SEARCHED* DA to EF Disc Swap Problem... (Ls_dx)
you really need to use your old/stock civic/crx one's the integra are slightly different and a tad longer then the civic..i have this issue prior. use your old civic/crx one.
Old Jun 1, 2006 | 10:33 PM
Ls_dx's Avatar
Default Re: *SEARCHED* DA to EF Disc Swap Problem... (C uR eX)
hm ok man good thing i kept them.. ill swap them over thx!!
Old Jun 2, 2006 | 08:16 AM
Ls_dx's Avatar
bump
Old Jun 2, 2006 | 08:25 AM
crx_88_si's Avatar
you were NOT supposed to remove that front bar on the rear trailing arm from the body. unbolt the trailing arm side only, now that you have already done that, you need an alignment.
Old Jun 2, 2006 | 08:32 AM
Ls_dx's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">you were NOT supposed to remove that front bar on the rear trailing arm from the body. unbolt the trailing arm side only, now that you have already done that, you need an alignment.</TD></TR></TABLE>
hm i guess i should have not done that but its too late now.... i can get them in the same spot they were... do you think the integra ones and crx ones are different??
Old Jun 2, 2006 | 08:36 AM
temp's Avatar
Default Re: (Ls_dx)
http://www.fourthgenhatch.net/reardiscswap.html
/thread
Old Jun 2, 2006 | 08:42 AM
crx_88_si's Avatar
Default Re: (Ls_dx)
yes... i believe all the integra control arms on the rear suspension are 1/16" longer.
i have no first hand experience, but this is what i gather from posts and other how to's.
Stick w/ the crx (or whatever your car is) arms.
Old Jun 2, 2006 | 08:44 AM
temp's Avatar
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">http://www.fourthgenhatch.net/reardiscswap.html
/thread</TD></TR></TABLE>
Old Jun 2, 2006 | 08:46 AM
Ls_dx's Avatar
Default Re: (temp)
thanks for that info, temp...
Old Jun 2, 2006 | 08:50 AM
temp's Avatar
Default Re: (Ls_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_dx &raquo;</TD></TR><TR><TD CLASS="quote">thanks for that info, temp... </TD></TR></TABLE>
/thread
Loserkidwac
Mar 3, 2007 09:57 AM
model x
21
Feb 4, 2007 01:53 PM
g2typeryellow
Apr 7, 2005 08:47 PM
Rob.
18
Mar 31, 2005 07:32 PM
singlecamcrx
13
Jan 13, 2005 04:14 PM
