pcv valve and broken ring lands...related?
i was just running the stock honda pcv system at 12psi boost with conservative tune and timing. now the ring lands are busted so can that be related to the crankcase not releasing pressure becuase of the pcv that only works in vacuum not boost?
i just have my pcv from the block venting into the air.. it still seems to blow out air fine without vacuum. will this be ok ? i dont see what it will hurt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">i just have my pcv from the block venting into the air.. it still seems to blow out air fine without vacuum. will this be ok ? i dont see what it will hurt</TD></TR></TABLE>
If you took the PCV valve out it will be fine. The only reason vacuum is required to vent the crankcase pressure is because the PCV valve is designed to only open under vacuum.
I simply pulled my PCV valve out of the black box on the back of my D16Y8 block (this is basically an OEM catch can), hollowed out the valve so it stays open all the time, and ran a hose from it down to the bottom of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">so will the harmful vapors still escape into the atmosphere then or should i remove the pcv and vent it with only a filter </TD></TR></TABLE>
Why don't you just do what I did and then use the filter on the valve cover. The mod I did is free, the filter is cheap, and it's easy to do. You just can't pass emissions if that's something you have to worry about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Helsinki »</TD></TR><TR><TD CLASS="quote">I highly doubt that crankcase pressure killed your ringlands, I think too much power and/or detonation is what killed the stock pistons.</TD></TR></TABLE>
anyone else agree? i dont know what to think? the tune was good, no detonation, 12:1 afr. conserviative timing
A buddy just broke his ringlands on his b16a at 10psi with a 42/48 turbo. Air/Fuel was at 11.9-12.1 and timing was definately conservative. There was no catch can installed, just using the regular pcv system. The plugs look great no fouling, broken porcelein anything like that. We disassembled the motor and found that the number 4 piston had broken apart from the inside, meaning from too much lower pressure. You can tell by the way the cracks/hole in the ringland is.
It is highly probable that crankcase pressure could have killed your engine as it most certainly killed my friends. (Also at the dragstrip the engine started to smoke because the dipstick blew right out spraying oil all over the manifold. Now that's too much pressure).
I agree. I’m sure elevated crankcase pressure could have added to the situation. I’m not sure what turbo you were running but something like a 60-1 @ 12psi would be putting down some impressive power, easy 300hp or so. That around the limits of stock pistons especially it conditions had changed since your tune and some detonation reared its ugly head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">
I agree. I’m sure elevated crankcase pressure could have added to the situation. I’m not sure what turbo you were running but something like a 60-1 @ 12psi would be putting down some impressive power, easy 300hp or so. That around the limits of stock pistons especially it conditions had changed since your tune and some detonation reared its ugly head. </TD></TR></TABLE>
it was a t3/4 57 trim. i was not making that much power. come on guys, it has to be related to the pcv system and no catch can. anyways, its fixed now and ill reinstall my catch can and well see how long it lasts again. im guessing alot longer with close to the same tune and same boost
in boost that valve is closed. there is an insane amount of pressure from the combustion chamber pushing down and hten in the crankcase pusing up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremydde »</TD></TR><TR><TD CLASS="quote">A buddy just broke his ringlands on his b16a at 10psi with a 42/48 turbo. Air/Fuel was at 11.9-12.1 and timing was definately conservative. There was no catch can installed, just using the regular pcv system. The plugs look great no fouling, broken porcelein anything like that. We disassembled the motor and found that the number 4 piston had broken apart from the inside, meaning from too much lower pressure. You can tell by the way the cracks/hole in the ringland is.
You're kidding right? The piston in that pic is melted..that means the piston got hot from running lean...that's got nothing to do with crankcase pressure.
</TD></TR></TABLE>You're kidding right? The piston in that pic is melted..that means the piston got hot from running lean...that's got nothing to do with crankcase pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_turd »</TD></TR><TR><TD CLASS="quote">I'm gonna say NO. Like someone already stated above, how sure are you there was no detonation?
And that piston encountered some lean condition if ive ever seen one. haha.</TD></TR></TABLE>
because i never heard it and my plugs didnt have any black specles and were burning perfect. the wideband shows an almost perfect afr of 12:1 at WOT and the timing is at .85* per pound boost. i was boosting 12 for a long time and then upped it to 15.
a bad batch of gas, hot iats, a tiny dip in your "12:1" A/F... could have been anyone of them. I could see how maybe a stock pcv system sucking in oil and causing detonation but thats it.
