smokin bad
Old Jun 1, 2006 | 08:17 PM
mylsspecteg's Avatar
Default smokin bad
recently i semi rebuilt my bottom end. After replacing my rod bearings, i decided to put new pistons and rings in my car while it was apart. 91 ls) I bought p 73 type r pistons 11 to 1 compression. After puttin everything back togehter, my car is smoking very bad. White smoke is coming out the tailpipe and its burnin oil like crazy. NO signs of headgasket leaking. Number 4 cylinders exhaust port is full crudded up oil and this has happened within bout 3 days. The spark plug for the same cylinder keeps foulin out due to excessive oil on it. Anyone know what the problem could be.
Old Jun 1, 2006 | 08:19 PM
Dartanian's Avatar
Default Re: smokin bad (mylsspecteg)
Did you hone the cylinders when the rings were replaced?
Sounds like your rings didn't seat properly and will most likely have to be replaced. Do a compression/leakdown test to make sure.
Old Jun 1, 2006 | 08:36 PM
Default Re: smokin bad (Das Schmoo)
yeah, im not sure why they wouldnt have seated properly, i have checked for any ridges or marks and there is none. THe motor was damn near perfect cept for rod bearings. How many miles does it normally take to seat a set of rings?
Old Jun 1, 2006 | 08:47 PM
Dartanian's Avatar
How and what did you hone it with?
It is debated on how long it takes for rings to seal, but it is done relatively soon. When I replaced my piston rings, there was no smoking at all during the first startup.
central_driver
Jul 28, 2010 11:30 AM
acman1
Jul 27, 2007 04:20 AM
crx1856
Sep 25, 2003 08:21 PM
Jared
Sep 7, 2001 10:55 PM
