blk smoke when i open the vtec, is this bad?
well, first off, don't open the vtec, because sometimes its hard to shut. second, i agree that you are running rich, do you have the right computer? any excessive fuel mods? adjustable fpr, injectors, fuel pump???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9tl »</TD></TR><TR><TD CLASS="quote">no everyting is stock. I kno the check engine light is on but its throwing lots of codes. The codes are 10-41-54-63-91-74. I dunno what it is./</TD></TR></TABLE>
ummm.... shouldn't your post have been, "i'm thorwing the following codes"? then someone would tell you to search, then you'd do that, and find out the codes mean (fill in the blank) , and then we wouldn't even have to address the black smoke issue?
get the right ecu thats probably the problem alot of cars always smoke when you mash on the gas abnd hit vtec its normal i think ... i know that when ever my chech engine light is in my engine dont hit vtec the same or at all
Jesus Man.. Dont drive your car.. Its not running right and you gotta fix this before you beat on it.. you gotta be misfiring like crazy. Bad o2 Sensors COULD throw you into limp mode (also makes you run rich)
10 IAT - intake air temperature sensor
41 Primary oxygen sensor heater
54 CKF - crank fluctuation sensor
63 Secondary oxygen sensor
91 Fuel Tank Pressure Sensor low input
74 random misfire cylinder 4
thats the ting, when i open the vtec i notice that everyting seems to be normal> The car does not sound like its misfiring. It drives normal to me. PPl tell me tha the swap tha was done to it cudd be the prblem wiht the wiring harness makin it throw out those codes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">
yea definitely need to fix the above before you even drive your car... let alone "open vtec"!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9tl »</TD></TR><TR><TD CLASS="quote">thats the ting, when i open the vtec i notice that everyting seems to be normal> The car does not sound like its misfiring. It drives normal to me. PPl tell me tha the swap tha was done to it cudd be the prblem wiht the wiring harness makin it throw out those codes.</TD></TR></TABLE>
Definately could be a harness issue.. also could be a ECU issue.
what ECU are you using? are you 96-98 or 99-00?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzai msg »</TD></TR><TR><TD CLASS="quote">make sure you refrigerate your vtec after opening</TD></TR></TABLE>
no doubt, but make sure it pops the first time you open it, that means its fresh!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9tl »</TD></TR><TR><TD CLASS="quote">well i got the p73 obd2. what poppin noise shudd i listen for.What shudd i do to hear it closely?</TD></TR></TABLE>
i wouldnt recommend driving it until you get rid of those CEL's
turn on the car, hold your ear to the valve cover, and hold the throttle at wot and hold it there for about 5 minutes, if you hear a loud pop, its broken
Jesus can you guys stop bashing the guy.. he is here and he is following the rules..
He is here to learn something about his car and figure out whats wrong with it.
Please try to stay on topic.. Bash only those that deserve to be bashed. this guy doesnt need it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Jesus can you guys stop bashing the guy.. he is here and he is following the rules..
Please try to stay on topic.. Bash only those that deserve to be bashed. this guy doesnt need it</TD></TR></TABLE>
don't think i agree with ya there guy, he needs to do more research before he touches that car, a mechanic should handle this one
WOW. Why would you want to attemp to drive the car w/o even knowing what those codes were? You need to fix all the problems before you open the vtec, and break it all.
From: On a island w/ only a bridge to leave it, U.S.A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 »</TD></TR><TR><TD CLASS="quote">turn on the car, hold your ear to the valve cover, and hold the throttle at wot and hold it there for about 5 minutes, if you hear a loud pop, its broken</TD></TR></TABLE>
Dont do that...
Dont do that...
