What cams is everybody using?w/turbo?
Old Apr 14, 2002 | 06:56 PM
MysteriousGSR's Avatar
Default What cams is everybody using?w/turbo?
yeah i was wondering what cams to go with for forced induction or with just nitrious i had in mind civic type r , zex,or jg.any other suggestions will be very helpful thanks
Old Apr 14, 2002 | 07:16 PM
StinkyTofu's Avatar
Default Re: What cams is everybody using?w/turbo? (MysteriousGSR)
Use stock cams, they the best
Old Apr 14, 2002 | 07:31 PM
Default Re: What cams is everybody using?w/turbo? (StinkyTofu)
really are u sure cause i mean i'll get more power out of the type r cams and there stock 2
Old Apr 14, 2002 | 07:42 PM
zojirushi's Avatar
My friend is using the Crower 402T cams for his LS turbo. Pulls hard. I give it a
Old Apr 14, 2002 | 08:32 PM
B18 B e a s T's Avatar
Not always true. If he has a GSR like his sn says, then he would want to use special turbo cams. The stock cams dont allow much power in midrange because of longer duration so boost leaks untill higher rpm. For a GS-R you can buy turbo VTEC cams which will probably increase your midrange with manipulation of the VTEC engagement point.
Old Apr 14, 2002 | 10:47 PM
SIK IN DA HED's Avatar
New User
Default Re: What cams is everybody using?w/turbo? (B18 B e a s T)
stock cams
Old Apr 14, 2002 | 10:49 PM
dubster99's Avatar
Default Re: What cams is everybody using?w/turbo? (dlplayboy)
Custom grind or VTEC turbo cams
Old Apr 15, 2002 | 08:22 AM
vtec2nr's Avatar
Stock GSR intake cam with an ITR/CTR exhaust cam. The GSR cam will reduce overlap, while the lift of the CTR/ITR exhaust cam will aid in exhaust removal.
[Modified by vtec2nr, 12:23 PM 4/15/2002]
Old Apr 15, 2002 | 06:47 PM
Default Re: What cams is everybody using?w/turbo? (vtec2nr)
thanks for your guy's help
rocket256
Aug 25, 2003 09:04 PM
93 VTEC
Jan 24, 2003 07:11 AM
GoldenONE
May 21, 2002 07:58 AM
VRxDReGoNxGSR
Jul 15, 2001 10:16 PM
hydroflip
Jul 11, 2001 10:17 PM
