Romulator problem.. Anyone?
Old Jun 1, 2006 | 05:35 PM
Turbo-Honda's Avatar
Default Romulator problem.. Anyone?
I'm doing some street tune, but when I load ROM into my Romulator it load fine everything went ok(blue bar were loading about 5sec) I turn off the ignition, then back on to check for red light on hondata blue box and it not solid, it blinking which mean map was not loading.. Anyone could help me why the map not load?.
I was thinking of connection problems, but what could it be. Here what I did:
1) Connect romulator onto chippedp28 (red pin one toward harness)
2)Keyspan usb port onto romulator.
3) open romeditor check emulator tab for Transonic romulator and said conneced. Then open a ROM file ..Or base map..
4) Hook interface blue box red lead onto chipped ECU
5) Hit contrl W and blue loading bar load for 5 sec then stop.
6) Last turn off ignition key then back on.
They said the red light should be solid. But mine was blinking.. I try it several times,but still blinking.. ECU + s200 were good because I current run someone basemap just to check out if the car were ok..Romulator were first time use also(it load, so I think it good)
Thank you very much if anyone could point me out something I miss.
pollito1320
Oct 28, 2011 08:46 AM
timisyourfriend
Jan 24, 2006 12:45 PM
platinum00
Aug 17, 2003 08:49 AM
hybrid901
Jun 16, 2003 05:13 AM
APZGSR
Dec 16, 2002 04:38 AM
