Are there OBD0 and OBD1 D-series alternators?
I have just been looking at some stuff about my swap. My question is, is there a such thing as an OBD0 alternator and an OBD1 alternator for a D-series? I am just trying to rule some stuff out. If there is, how can you tell the difference and is the wiring and mounting different. My motor before the swap had a few A6 parts and it is a Z6.
I didn't do the swap, just bought the car ghetto rigged.
obd == on board diagnostics. Alternator has nothing to do with obd. I would be shocked if the alternators were not interchangeable between an a6 and z6.
they both will mount up but the plugs are differant... obd1 is green and obd0 I think is white if i remember from my crx days
The BIG difference between the two on a D-series motor is the pulley. 1988-1991 alternators use a three rib serpentine belt, while 1992-1995 alternators use a four rib belt (similar to ALL B-series). Also, the 1992+ alternators are somewhat bigger, and appear to be higher output units. But I would think that newer alternators are compatible with older ECUs (and vice versa). They are with B-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">both are 100% plug and play.</TD></TR></TABLE>yup correct, the rib count is the same for the belts. the main difference is that the CRX one is a 60 amp and the 92 up are 70 amps.
plugs are the same, as is mounting locations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">. 1988-1991 alternators use a three rib serpentine belt, .</TD></TR></TABLE>do you have a pic of this 'serpentine' belt?
The pulley's are different... My CRX HF had the thinner belt while A/C belt was wider. Then when I got my OBD1 JDM D15B VTEC motor w/ alternator on, it had a wider alternator belt; exact same width as A/C belt.
You can use either one. The difference is also noticable on their crankshaft pulley.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC »</TD></TR><TR><TD CLASS="quote">The pulley's are different... My CRX HF had the thinner belt while A/C belt was wider. Then when I got my OBD1 JDM D15B VTEC motor w/ alternator on, it had a wider alternator belt; exact same width as A/C belt.
You can use either one. The difference is also noticable on their crankshaft pulley.</TD></TR></TABLE>this must be form the diffrence in compressors since my DX had the wider belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NastyHabitzCRX »</TD></TR><TR><TD CLASS="quote">this must be form the diffrence in compressors since my DX had the wider belt.
Compressors?
Okay, so it would seem that HF's had the thinner alternator pulley while all/most others have the wider one identical to the 92-95 Civics.
</TD></TR></TABLE>Compressors?
Vtec's My Anti-Drug
Feb 3, 2007 10:30 PM
white90rexsi
Jan 2, 2007 07:55 PM
altenater, alternator, altinaters, civic, conversion, diagnostics, difference, honda, interchangable, obd0, obd1, odb0, plug, plugs, series
