89 DX to SOHC ZC swap issues...help please
Old Jun 1, 2006 | 05:30 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default 89 DX to SOHC ZC swap issues...help please
89 DX hatch with SOHC ZC using 90 Si ecu...
idles fine, when attempting to accelerate, the car attempts to die...in other words, when I try to accelerate, it physically decels. Searched and alot of answers I read is TPS sensor either needing to be adjusted or is bad. Can anyone confirm or help with better information?
Thank you HT
Chris H.
Old Jun 2, 2006 | 06:36 AM
Default Re: 89 DX to SOHC ZC swap issues...help please (DAantagonist)
no one?
Old Jun 2, 2006 | 06:38 AM
temp's Avatar
are you getting a TPS sensor code? the TPS sensor code will not trip a CEL
Old Jun 2, 2006 | 09:11 AM
Default Re: 89 DX to SOHC ZC swap issues...help please (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">are you getting a TPS sensor code? the TPS sensor code will not trip a CEL</TD></TR></TABLE>
I don't think it tripped any CEL, I think the code was pulled from ECU...
Old Jun 2, 2006 | 09:14 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think it tripped any CEL, I think the code was pulled from ECU...</TD></TR></TABLE>
check your ECU, see if its throwing codes
Old Jun 2, 2006 | 01:22 PM
all of this is for a friend...so I'll find out...
Old Jun 2, 2006 | 01:30 PM
thevtecnician's Avatar
Ay I had the same setup as you and same problem too. It turned out to be that my vacuum lines coming from themap sensor were plugged wrong
Old Jun 2, 2006 | 03:19 PM
Default Re: 89 DX to SOHC ZC swap issues...help please (thevtecnician)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician &raquo;</TD></TR><TR><TD CLASS="quote">Ay I had the same setup as you and same problem too. It turned out to be that my vacuum lines coming from themap sensor were plugged wrong</TD></TR></TABLE>
good to know...will check that out...
thank you very much
Old Jun 13, 2006 | 01:03 PM
13
one is map, one is ECT, and one is IAT....map seems to be working fine...will dig further...
RyanJayx
Jul 6, 2009 01:42 PM
bluecivic05
Apr 17, 2007 07:28 PM
EG6-SIRII
Sep 11, 2006 03:22 PM
stehigs321
Jan 5, 2004 12:28 AM
FBPninetynineEM1
Jul 26, 2002 06:32 AM
