Project: My First Motor Build
Let me start off by giving a little background.
I do all my own work,for the most part, but I have never ever built a motor. I've put parts on one and taken them off, but never from the oil pan to valve cover.
I have a few tools and thats about it. Nothing else. I also have no money set aside for this so it will be a slow build so I don't cut into my other priorities. I will aquire tools and other needed supplies as well. I am literally starting from scratch.
I went out about bought this today:
To help me along. As well as my few tools I have that have saved my *** more than once
I also bought a full LS motor that was torn down by the PO and Never put back together.
I am somewhat sure what I want to do. I'm thinking of building it for boost, from the ground up. But in Retrospect, since it's my first motor, should I build it with OEM parts just to get some expirence at it?
So hopefully this will be my build thread. I plan on asking numerous questions once problems arise and look foward to help from the select few of knowledgable people that browse this fourm.
Thank you.
Thank you.
Build it for boost, I'm doing the same and I have never built a motor neither.
I will check in on this thread in case I have some problems along the way.
looks like you got a good start
to aid you I would invest in a torque wrench
and some plasti-guage
some other things that would help would be a honing bit, feeler guages, and a ring compressor
building a motor seems like a big task at first but it is not as hard as it seems once you start
good luck
good luck
Make sure you have a Helms manual available so you can check and see what tools you will need for the overhaul. I would build it for boost, though...if you end up still having enough money to turbo it.
Good luck.
Good luck.
you need a torque wrench or a torque guage but im sure you knew that
hopefully i will be starting on my first tranny build in a few weeks, THAT is hard
I have built a motor before, but it was a domestic, Chevy big block V8, plopped into an old cop car, then this was removed and replaced with a corvette engine a few years later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nors »</TD></TR><TR><TD CLASS="quote">how much for the engine stand? Now I need one
I got mine at autozone. 750lb capacity. 55Bucks
</TD></TR></TABLE>I got mine at autozone. 750lb capacity. 55Bucks
B18C_EJ8
Sep 27, 2004 02:04 PM
Plan B
Jan 6, 2003 09:28 AM
