Dumb question? Wiring for two amps...
I have two amps. 400 RMS and 600 RMS. Would it be best to connect these to the battery with two seperate 4 guage power wires and two separate fuses? Or should I use a terminal to join them and then one big *** fuse?
It should be enough to run one 4 gauge wire from the battery, and then use a distribution block to connect the 2 amps. It would be a good idea to put a fuse on the wire between each amp and the distribution block. But if the amps have built-in fuses, then one fuse by the battery would be enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZeeSix »</TD></TR><TR><TD CLASS="quote">I have two amps. 400 RMS and 600 RMS. Would it be best to connect these to the battery with two seperate 4 guage power wires and two separate fuses? Or should I use a terminal to join them and then one big *** fuse? </TD></TR></TABLE> Run 2 power leads 4ga for the 600W amp with a 150A MAX waffer, [anl] fuse byt the batt, you could get away with an 8ga for the 400W amp and a 100A MAX waffer, [anl] fuse if the amp is about 8ft from the batt., [under seat] but if its closer to 12ft from the batt., [in the rear] use another 4ga with the 150A MAX fuse.
The fused are there to protect the power cable not the amp, and a proper distrobution block for power will have fuse holders in them, although I am no fan of distrobution blocks, if you want to use one run a 2ga cable to it with a 225A MAX waffer, [anl] fuse and then a 4ga to the 600W and an 8ga to the 400W from the dist. box and again up to 150A for the 4ga and 100A for the 8ga in the dist. block.
94
94
90crxdriver
34
Mar 28, 2007 03:52 PM
JoshuaVTEC
Audio / Security / Video
Apr 19, 2003 09:38 AM
