Prelude pistons
Old Jun 1, 2006 | 05:43 AM
92_civic's Avatar
Default Prelude pistons
I know that there are very few aftermarket pistons that will work with a stock bore
h22a engine, what I am wondering is are there any other options besides re-sleeving the block, for instance can you bore the stock cylinder coating off and run a regular piston, or is there not enough cylinder to do that?
I am trying to build this engine for turbo, and would really like to get away from the stock rods and pistons, but the more research I do it seems like sleeving the block is the only solution. thanks in advance for any replies I do appreciate the help, I'm a bit of a newbie when it comes to the h22
Old Jun 1, 2006 | 05:59 AM
prelittlelude's Avatar
Default Re: Prelude pistons (92_civic)
there is a huge thread in the FI forum , search for mahle pistons.. they supposedly work well with the frm cylinders found in the h series.
Old Jun 1, 2006 | 08:18 AM
92_civic's Avatar
thanks
Old Jun 1, 2006 | 03:10 PM
silentvoice19's Avatar
theres a place that will sleeve your block for 466 bucks the sleeves will hold 50 lbs of boost.Nice guys my block is there right now.Or go with the mahle slugs only other solution.
Old Jun 2, 2006 | 11:20 AM
92_civic's Avatar
Default Re: Prelude pistons (silentvoice19)
do you have any contact information for them?
Old Jun 2, 2006 | 11:37 AM
darkspector's Avatar
talk to precisionh23a his place is supposed to do great machine work. I'm sure others can vouch for him
cluelessmale
May 28, 2007 07:43 PM
Maddox
Jun 6, 2004 08:53 AM
v4lu3s
May 30, 2003 02:09 PM
p10hlm
Jan 7, 2003 11:25 PM
gtcali
Jun 14, 2002 03:49 AM
