95 auto tranny not shifting
Old May 31, 2006 | 11:42 PM
deeweezy187's Avatar
Default 95 auto tranny not shifting
Today i was driving and my transmission was messing up. It will not shift into gear and all is does is rev when trying to go up hill. It doesn't accelerate it just starts to rev. But when you turn the car off and turn it back on it drives normally for a little bit. I don't know when the car has had a transmission flush because the car was handed down to me from my mom. Could i need a flush? Oh yeah the check engine light came on.
Old Jun 1, 2006 | 02:41 AM
Default Re: 95 auto tranny not shifting (deeweezy187)
o yeah and when you put the car in drive it just drifts back like its in neutral and it doesn't go forward
Old Jun 1, 2006 | 04:32 AM
S CARTER's Avatar
Definitely start out with an ATF flush and make sure to use the honda ATF-Z1
http://www.drivah.com/marketpl...1.jpg
Old Jun 1, 2006 | 05:54 AM
CfOuUcGkH CyOoUuG!H's Avatar
Default Re: 95 auto tranny not shifting (S CARTER)
may be a stupid question.... but what is the difference in a "flush" and just changing your tranny fluid?
Old Jun 1, 2006 | 05:58 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: 95 auto tranny not shifting (XxRosser MafiaxX)
Draining and filling will only replace about 3 quarts. A flush replaces all 9 quarts.
I definately agree with S Carter for a start. If not then you may have a crapping TCU.
Old Jun 1, 2006 | 06:05 AM
Default Re: 95 auto tranny not shifting (MooGoCow3)
ok... how do you do a flush or can u get it professionally done?
Old Jun 1, 2006 | 06:10 AM
Ross 2.0's Avatar
You can either drain and fill it three times while driving it a little after re filling it.
or you can have it hooked to a flush machine and all 9 can be flushed at once (never put additives with the fluid).
But Honda reccomends the first one
Old Jun 1, 2006 | 11:34 PM
raceACCORDingly's Avatar
same thing happend to me a few yrs back, clutch packets were gone and the filter/screen thing inside the tranny was clogged. i think the clog prohibited proper ATF pressures and caused the clutch packets get thrashed. the 2 yrs of nitrous i put through is most likely the cause of all that madness. i converted to a manual and havent looked back since...
werent you turbo'd?
Old Jun 3, 2006 | 08:55 AM
Default Re: (raceACCORDingly)
wish i was trying to be tho. I might just garage the accord and whip the caddy for a while and save up and buy all my parts to convert my car to manual. gas is going to kill me but in the long i will be happier.
Old Jun 3, 2006 | 02:08 PM
hondadude's Avatar
"Oh yeah the check engine light came on. "
What Code?
Old Jun 4, 2006 | 05:32 AM
Default Re: 95 auto tranny not shifting (hondadude)
i didn't even check it yet.
Nate.Hamm
Jan 12, 2021 01:45 PM
specialty
Honda CR-V & Element
Oct 16, 2012 05:37 AM
deeweezy187
May 26, 2006 04:07 AM
KDoGx504
Oct 19, 2005 07:23 AM
BoostedSi
Sep 13, 2003 08:39 PM
