Radiator overflow....
I tried starting my car with the rad cap off to see if there was any air in the system and after just a few seconds the coolant in the rad filler neck started to rise and overflow...
Is this normal?
Is there another way to bleed the air out of my cooling system?
Is this normal?
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackpearlv6 »</TD></TR><TR><TD CLASS="quote">I tried starting my car with the rad cap off to see if there was any air in the system and after just a few seconds the coolant in the rad filler neck started to rise and overflow...
Is this normal?
Is there another way to bleed the air out of my cooling system?</TD></TR></TABLE>
Thats completely normal, bleed from the bleeder screw on top of the thermostat.
Is this normal?
Where exactly is the thermistat on a 95 v6 exr? Anyone have a picture? To Bleed I
loosen the bleed bolt
turn the heat up high
start the car
...then what...
start the car
...then what...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackpearlv6 »</TD></TR><TR><TD CLASS="quote">Where exactly is the thermistat on a 95 v6 exr? Anyone have a picture? To Bleed I
start the car
...then what...</TD></TR></TABLE>
there's detailed step by step diagram with picture in your manual, under coolant section(at least i have for my last three honda's)
i don't have a 5th gen but the bleeder screw is located the highest point of the cooling system and it's not the radiator cap.
bleeding air for cooling system
1)a/c turn to high, with heat to the max and non circulation mode
2)start the car
3)lossen bleeder screw, you should see coolant coming out, a stop and go coolant flow is a sign that air is coming out.
4)wait until you see the coolant is coming out in a uniformed size stream.
5)tighten screw and you are done
start the car
2)start the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerElfboy »</TD></TR><TR><TD CLASS="quote">do you mean just give it a little bit of gas while the cap is off or really rev it?</TD></TR></TABLE>
never has to go much above 3K unless you just want to see how high it can go.
Bill Leland
Jun 12, 2014 02:29 PM
tmurda253
13
Nov 4, 2008 08:53 PM
return_2020
12
Feb 12, 2005 05:51 AM
