3rd gear poping out of gear
3rd geat pops out while driving could it be the clutch or Syncro or combination of both? curious before i spend more money then i have too
Thnka in advance
Thnka in advance
before anything you need to check the shift linkage/cables for damage(bent, cracked), adjustment. check the shifter to make sure there is no physical interference. Broken trans/ engine mounts can also cause this.
As for internal problems it could be worn detent springs, bent shift rod or fork, too much input shaft endplay, worn syncronizer, worn dog teeth on the gear or synchro.
92civiceg9gsr
Transmission & Drivetrain
Feb 6, 2009 08:53 PM
TypeSH
Jun 9, 2002 12:00 PM
