SC6152E VS GT35-61
Old May 31, 2006 | 07:11 PM
spec_v_kid's Avatar
Default SC6152E VS GT35-61
I am thinking get a little bit bigger and better turbo, was told by some friend the
GT35-61 T3/T4
61MM compressor wheel
GT35 turbine wheel
TO4E compressor cover with .60 A/R
T3 turbine cover with .63 A/R
Supports up to 550HP
is better than my precision sc6152e, which i made 408whp on pumpgas @ 19psi...
is it worth it to get that turbo? What turbo will be better for 430-450whp (power band)???
Old May 31, 2006 | 07:15 PM
Zakar's Avatar
i'm sure its quite a bit more expensive too.. why dont you just up the boost?
Old May 31, 2006 | 07:27 PM
spec_v_kid's Avatar
Default Re: (Zakar)
$795.00 from turbounlimited.com
Old May 31, 2006 | 07:29 PM
siblues's Avatar
Default Re: (Zakar)
http://www.nolimitmotorsport.com/prod/SCM-6152E
Those are the specs for your turbo and it doesnt look to be much different and supports 630 max hp?
Old May 31, 2006 | 08:19 PM
TheShodan's Avatar
Moderator
630hp is a CRANK number.. You must account for about 15-20 percent driveline loss.
Old Jun 1, 2006 | 05:05 AM
spec_v_kid's Avatar
Default Re: (TheShodan)
any more turbo geeks?
civic2slo
Apr 2, 2014 07:31 PM
mrbsponge
Sep 29, 2004 06:11 PM
Acura_I-RS
Apr 13, 2003 06:42 PM
