my friend got a small problem! need some serious help
Old May 31, 2006 | 06:41 PM
25Type-s's Avatar
Default got a small problem! need some serious help
i just wanted to thank everyone that helped me out with the problem that i had>
EDIT
So Smithtown Acura gave me a call today telling me that a valve fellinto cylinder #4 and damaged everything in there soo they are giving me a brand new engine
LUCKY ME !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! VERY LUCKY ME!!!!!!!!!!!!!!!!!!!!!!!!
Modified by 25Type-s at 6:49 AM 6/8/2006
Modified by 25Type-s at 7:09 AM 6/8/2006
Old May 31, 2006 | 08:27 PM
blurryaltezza's Avatar
Default Re: my friend got a small problem! need some serious help (25Type-s)
yea that ***** is not good
Old May 31, 2006 | 08:52 PM
NiPBoi's Avatar
Default Re: my friend got a small problem! need some serious help (blurryaltezza)
probably bent some valves...someone did that here awhile ago and he had pics of a valve in his piston after it bounced around the cylinder
Old May 31, 2006 | 09:04 PM
Kal's Avatar
Kal
bent valves more than likely. take off the head and make sure.
Old May 31, 2006 | 11:23 PM
Spracer03's Avatar
ouch... thats a costly mistake
Old May 31, 2006 | 11:27 PM
KOREAN's Avatar
Default Re: (Spracer03)
bad times!
Old Jun 1, 2006 | 06:42 AM
25Type-s's Avatar
Default Re: (korean)
thanx to all of u for the help. if he bought an extended warranty on the powertrain would it be covered?????
Old Jun 1, 2006 | 06:48 AM
kung fu grip's Avatar
Default Re: (25Type-s)
he needs to pour over the fine print of his extended warranty contract. he may have to fight the company covering this to get the work done. the ECU is going to tell the dealer that he overrevved.
Old Jun 1, 2006 | 06:58 AM
JDMcb7's Avatar
its called the money shift
Old Jun 1, 2006 | 07:01 AM
nautica_t's Avatar
yeap good ol' money shift, better be careful about that
sounds like you have bent valve.s
Old Jun 1, 2006 | 07:24 AM
25Type-s's Avatar
Default Re: (kung fu grip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kung fu grip &raquo;</TD></TR><TR><TD CLASS="quote">he needs to pour over the fine print of his extended warranty contract. he may have to fight the company covering this to get the work done. the ECU is going to tell the dealer that he overrevved.</TD></TR></TABLE>
even though he had the code cleared all tha comes up now is that the cylinders are misfireing
Old Jun 1, 2006 | 11:10 AM
eff sea's Avatar
Yeowch.
**** like this is the reason why I learned to drive stick on a rotary
At the very least he's going to need the valves readjusted. If the valves are bent... well, your **** out of luck.
Old Jun 1, 2006 | 12:09 PM
NJslvrtypes's Avatar
The reason it is mifiring is because he bent valves not because of the code. Acura will not cover this under warranty most likely and when they scan the ECU they can see at what time and RPM he misshifted. And no this can't be erased.
If he gets lucky they will replace it under what they call "Good will" but chances are slim. Best bet is too either DIY or take it to a shop other than a stealership.
And stop driving the damn car too, if the valves are just bent you don't want them to snap. Then you can say goodbye to the block and pistons too. Sorry to be blunt but this simple issue can turn into a catastrophe.
Old Jun 1, 2006 | 12:26 PM
25Type-s's Avatar
Default Re: (NJslvrtypes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJslvrtypes &raquo;</TD></TR><TR><TD CLASS="quote">The reason it is mifiring is because he bent valves not because of the code. Acura will not cover this under warranty most likely and when they scan the ECU they can see at what time and RPM he misshifted. And no this can't be erased.
And stop driving the damn car too, if the valves are just bent you don't want them to snap. Then you can say goodbye to the block and pistons too. Sorry to be blunt but this simple issue can turn into a catastrophe.</TD></TR></TABLE>
the car can still start with bent valves???
Old Jun 1, 2006 | 01:03 PM
Depending on the severity, yes but it will idle like ****.
Old Jun 1, 2006 | 05:22 PM
BoBoChan's Avatar
how do you go from 3rd to 2nd..
can no one pull straight down?
like, fuggin, 2nd to 1st is understandable but 3rd to 2nd.. :/
Old Jun 1, 2006 | 05:27 PM
25Type-s's Avatar
Default Re: (BoBoChan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">how do you go from 3rd to 2nd..
like, fuggin, 2nd to 1st is understandable but 3rd to 2nd.. :/</TD></TR></TABLE>
srry it was from 5th to second
Old Jun 2, 2006 | 10:37 AM
NiPBoi's Avatar
5th to 2nd!!! ouch...
Old Jun 2, 2006 | 05:37 PM
k20tuner's Avatar
The ECU has a black box built into it so that if there is any large trauma to the engine (ex. over reving the engine to the point of bending valves) it stores all of the engine activity from the point of boom the 30 seconds before. In this case showing the bad shift, rpms and how long the engine was held at those rpms and this CANNOT be erased , removed or altered in any way unless you have access to an Acura dealership. Erasing the over rev code will only show them that he tried to cover it up. But when they look at the valve train they will see bad things, check the engine records in the ecu and because it was driver error and not a fault of Honda, I highly doubt that they will even consider doing warranty work. Don't even think about cranking that motor or even consider driving it cause if you loose a valve completely you just lost your engine. Look at it this way, he has a golden opporitunity to upgrade the valve train and port and polish the heads.
Old Jun 2, 2006 | 06:29 PM
25Type-s's Avatar
Default Re: my friend got a small problem! need some serious help (k20tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20tuner &raquo;</TD></TR><TR><TD CLASS="quote">The ECU has a black box built into it so that if there is any large trauma to the engine (ex. over reving the engine to the point of bending valves) it stores all of the engine activity from the point of boom the 30 seconds before. In this case showing the bad shift, rpms and how long the engine was held at those rpms and this CANNOT be erased , removed or altered in any way unless you have access to an Acura dealership. Erasing the over rev code will only show them that he tried to cover it up. But when they look at the valve train they will see bad things, check the engine records in the ecu and because it was driver error and not a fault of Honda, I highly doubt that they will even consider doing warranty work. Don't even think about cranking that motor or even consider driving it cause if you loose a valve completely you just lost your engine. Look at it this way, he has a golden opporitunity to upgrade the valve train and port and polish the heads.</TD></TR></TABLE>
damn thanx for the info but i dont got that much money to upgrade al those things even though i would love to do it
Old Jun 2, 2006 | 07:14 PM
. L 3 3 7 H X R's Avatar
that is why you don't let idiots drive your car... friends who don't know how to drive stick..especially on RSX-S which are EXTREMELY infamous to known to be easily mis-shift and screw up the motor when you go past redline...
do a search... almost everyone who mis-shifted RSX-S past the rev limiter screwed the motor up like crazy...
Old Jun 3, 2006 | 11:22 AM
k20tuner's Avatar
Just start looking for new valves and have the springs and retainers looked at. If the only thing that got messed up were the valves than you are good to go. You can get a new set of valves from Ex. skunk2 for about 370, and thats from there website so the're out there cheaper somewere. Start shopping for valve sets or even a kit with the valves retainers and springs. I have a feeling it will be alot cheaper than rebuilding the whole motor when one of the bent valves goes or buying a new car or engine. You have a k-motor, TUNE IT WHILE YOU CAN, lol. Have the WHOLE motor looked at and if the only thing that needs replaced is the valves then drop a nice set in there (you get what you pay for alot of the time) and you just got you daily driver back for less than 400 bucks plus labor, but find someone you trust or can show you some of there work. Then later down the road look at upgrading the springs and retainers and next thing you know if you bought the right parts you have one hell of a head. Look at possibilty.
Try looking at some of these places for parts:
http://www.clubrsx.com
http://www.skunk2.com
http://www.honda-performance.com
Old Jun 3, 2006 | 11:31 AM
25Type-s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20tuner &raquo;</TD></TR><TR><TD CLASS="quote">Just start looking for new valves and have the springs and retainers looked at. If the only thing that got messed up were the valves than you are good to go. You can get a new set of valves from Ex. skunk2 for about 370, and thats from there website so the're out there cheaper somewere. Start shopping for valve sets or even a kit with the valves retainers and springs. I have a feeling it will be alot cheaper than rebuilding the whole motor when one of the bent valves goes or buying a new car or engine. You have a k-motor, TUNE IT WHILE YOU CAN, lol. Have the WHOLE motor looked at and if the only thing that needs replaced is the valves then drop a nice set in there (you get what you pay for alot of the time) and you just got you daily driver back for less than 400 bucks plus labor, but find someone you trust or can show you some of there work. Then later down the road look at upgrading the springs and retainers and next thing you know if you bought the right parts you have one hell of a head. Look at possibilty.
http://www.honda-performance.com</TD></TR></TABLE>
hey thanx for the input and the advice i really hope they fix it under the warranty but i doubt it if the dont i know a mechanic that hopefully will do this for a good price and that i guess buy good valves hopefully thats all that is wrong...
Old Jun 3, 2006 | 01:25 PM
k20tuner's Avatar
Good luck with it all.
Old Jun 3, 2006 | 05:45 PM
25Type-s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20tuner &raquo;</TD></TR><TR><TD CLASS="quote">Good luck with it all.</TD></TR></TABLE>
hey how much di u think a valve job will cost???
