so i found the source of my sputtering/loss of power...
Old May 31, 2006 | 05:04 PM
Single Cam Loser's Avatar
Default so i found the source of my sputtering/loss of power...
yeah, that's the downpipe to my Megan Racing header, snapped off thanks to pressure from the lower tie bar. Hooray for me.
Question. will handling be offset if i have just a front upper strut tower bar and take this lower bar off for good?
Oh and feel free to laugh at my misfortune.
Old May 31, 2006 | 05:17 PM
wakeboard_dude5's Avatar
Default Re: so i found the source of my sputtering/loss of power... (Single Cam Loser)
i don't think strut bars add or take away any pressure at all... they're only there to keep everything rigid. My guess is the header snapped because you didn't re-use your spring bolts not because of a tie bar. But that's just my $.02
kKdARIAN's Avatar
Vice President/CEO
wow man, that sucks.. i bet that was pretty loud??
Old May 31, 2006 | 05:23 PM
Default Re: so i found the source of my sputtering/loss of power... (wakeboard_dude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakeboard_dude5 &raquo;</TD></TR><TR><TD CLASS="quote">i don't think strut bars add or take away any pressure at all... they're only there to keep everything rigid. My guess is the header snapped because you didn't re-use your spring bolts not because of a tie bar. But that's just my $.02</TD></TR></TABLE>
I know they aren't designed to add pressure, what i mean was (and sorry its not very clear from the angle of the pic) the tie bar actually rolled backwards (it was slowly shifting upwards due to scraping the ground when my car was slammed) and pushed up against the header pipe.
Old May 31, 2006 | 05:36 PM
spoonracer84eg's Avatar
I have to agree with him. You should have used bolts and springs to allow for movement. That and your header is a pos lol
Old May 31, 2006 | 05:41 PM
well definatly take that lower tie bar off, they don't do that much anyways. Now if you really want to stiffen up down there go for an H-brace, i've seen them for $65 shipped and from what i've heard they're awesome but not reccomended if you're still slammed. Personally i would replace that header and get some spring bolts on to prevent this from happining again.
Old May 31, 2006 | 06:07 PM
eh, megan racing headers are like half the price of DC, good bang for the buck I think. Woulda lasted longer for sure without the shitty suspension setup I was on before.
Thanks for answer the question about the lower tie bar though, i'll look into an h-brace.
Old May 31, 2006 | 06:25 PM
KingKhong's Avatar
mine did that, oh boy it sounded like an airplane!
Old May 31, 2006 | 06:59 PM
rmcdaniels's Avatar
Default Re: (KingKhong)
Cracking is pretty common if you don't use a flex joint.
Old May 31, 2006 | 07:26 PM
FalkenSiR's Avatar
Default Re: (rmcdaniels)
If you are a tie bar freak like me you should look into the integra lower tie bar (OEM). They came with one that is by the steering rack and bolts right into civics.
Old May 31, 2006 | 09:07 PM
DohcSide's Avatar
Default Re: (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Cracking is pretty common if you don't use a flex joint.</TD></TR></TABLE>
x2
my pipping would always crack and break apart until i got a flew pipe.
Old May 31, 2006 | 09:20 PM
EK79's Avatar
[img]https://i7.photobucket.com/albums/y284/fullmulletalchemist/nelson_ha_ha.jpg[/img.]
that sucks man good luck with that
you said we can laugh!
Old May 31, 2006 | 09:22 PM
EK79's Avatar
[image]http://img340.imageshack.us/img340/1791/brokenheader4rw.jpg[/image]
Old Jun 2, 2006 | 02:25 PM
hellshock2182's Avatar
Default Re: (DohcSide)
X3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcSide &raquo;</TD></TR><TR><TD CLASS="quote">
x2
my piping would always crack and break apart until i got a flex pipe.</TD></TR></TABLE>
Old Jun 2, 2006 | 03:10 PM
Ghetto Civic HX's Avatar
I love to drive
Default Re: (hellshock2182)
Old Jun 2, 2006 | 03:48 PM
Paxil4x4's Avatar
Default Re: (Ghetto Civic HX)
I would have noticed a noise problem before any drivability problem
Old Jun 2, 2006 | 04:33 PM
Default Re: (packthis)
trust me, the first thing i noticed was the noise but it happened at high end rpm so I was convinced the noise was a motor problem and not an exhaust problem until I spotted it.
maxis
Suspension & Brakes
Aug 29, 2011 08:48 PM
DIYaccord
Aug 18, 2004 11:40 AM
B18CYAAA
Dec 29, 2003 12:34 AM
wing
Oct 20, 2003 07:46 AM
revhrdls
Aug 4, 2001 03:51 AM
