Technical Question b16a1 vs b16a2
Greetings,
I'm a newb to this sort of thing and am trying to educate myself on the swap possabilities on a 93 del sol. I have narrowed down the various possabilities given my current financial situation to the b16 (although the other possabilities are certainly tempting). Recently I came across a JDM b16a1 for a decent price what I wanted to know what the exact differences between the b16a1 and the b16a2 are (beyond the horsepower increase from A1 to A2)? Is there another site where I can find the info? If I were to get a A1 am I limiting myself a great deal? any info and input is appreciated.
Depends on which year the B16A is from. If it's 1st gen, then the HP is no different from the B16A2. The only different is the OBD. However, the 2nd gen B16A has 10 more HP than the 1st gen and the A2. But basically, the different B16s are different OBDs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Depends on which year the B16A is from. If it's 1st gen, then the HP is no different from the B16A2. The only different is the OBD. However, the 2nd gen B16A has 10 more HP than the 1st gen and the A2. But basically, the different B16s are different OBDs.</TD></TR></TABLE>
couldn't explain it better
all jdm b16s are b16a and anything with a number after the b16a part like b16a2 means its a USDM motor. obd 0 b16a from the civic SiR and integra XSi had 160hp and the obd 1 b16a from the SiR2 civics and integra XSi had 170 hp. the number of the engine doesnt tell you how much power it has just where and what it came from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 »</TD></TR><TR><TD CLASS="quote">what motor does the 99-00 us si have? is it the b16a3?</TD></TR></TABLE>
no, the 99-00 civic have the b16a2
the 94-97 del sol's have the b16a3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhillySolNhatch »</TD></TR><TR><TD CLASS="quote">94-95 del Sol = b16a3
96-97 del Sol = b16a2
99-00 Civic SI = b16a2</TD></TR></TABLE>
96-97 b16a2? not trying to be an *** about this but, are you sure? if so how can you tell the difference from a del sol b16 and a civic si b16?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
96-97 b16a2? not trying to be an *** about this but, are you sure? if so how can you tell the difference from a del sol b16 and a civic si b16?</TD></TR></TABLE>
There is no difference. The reason why its A2 is because its OBDII. And A3 is OBD1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
There is no difference. The reason why its A2 is because its OBDII. And A3 is OBD1</TD></TR></TABLE>
hmmm...i always thought a3 was del sol's and a2 was si's. oh well good to know.
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 »</TD></TR><TR><TD CLASS="quote">wheres a good site to find a civic si motor for a 96-00 civic coupe</TD></TR></TABLE>
check the web, try local shops in your area. where you from?
thanks!
JJGL-EF90
10
Feb 7, 2010 06:16 PM
ulemu
Jan 9, 2006 04:28 PM
