OMNI-POWER CAMBER KITS, LOWER CONTROL ARMS, CMC, ETC. ALL ITEMS WITH FREE SHIPPING!!!
***UPDATE! 9/10 DRAG COILOVER SETS IN STOCK NOW! GET THEM NOW BEFORE THEY GO ON BACKORDER AGAIN!!****
****NEW 68MM AND 70MM THROTTLE BODIES IN STOCK NOW***
IAP offering all HT members FREE SHIPPING on all OMNI-POWER products! This includes: Full Coilovers, Slip-Over Coilvers, Front and Rear camber kits, Rear Lower control arms, QuickClutch Master Cylinder, Test Pipes, Etc. We gurantee the BEST PRICE paired with the BEST Customer Service you will find!!
Click Here to Purchase Your Omni-Power Products Now!!
NEW TYLITE COILOVERS!!
Tech Info Below:
Just released, Omni-Power Tilyte full coil overs with speed sensitive reactive damping. In development for over 1 year, our new Tilyte mono tube coil over is a combination of the most advanced materials and fluids to provide unsurpassed ride quality, longevity and razor sharp cornering response. Each Tilyte coil over incorporates a newly designed Omnipower piston which reacts to the slightest movement. We use an exotic SAE specially heat treated spring steel for our shim stacks that has up to 35% + higher fatigue resistance than competitors shims. Cycle testing was done to provide the most consistent performance over the longest possible life span. The new Omni-Power Tilyte coil over design is able to perform with in 2% of new after 400,000 cycles. We tested several different shock oils and found that Fina was able to provide the most stable oil viscosity and least amount of damping loss at maximum operating temperature. A new seal design ensures a leak free shock even under the most extreme conditions and years of abuse. The re-engineered damping provides an ultra smooth ride and instantly adjusts to any road surface condition.
Cycle testing and road testing were done during the R&D process in order to ensure maximum life and consistant performance . The guide lines Omnipower uses for cycle testing are as follows:
Cycle stroke: 50mm
Cycle speed: 300mm/sec
Cycle duration: 400,000 cycles
1 Cycle= 50mm up and 50mm down or 100mm of movement.
In order to provide the best possible consistency, we build smaller production runs and randomly select a few shocks from each. Randomly selected shocks are dyno tested and compared to a master curve for their part number before the production run is released for sale.
Street full coilovers:
Front 10kg/mm spring rate (560 Lbs/inch)
Rear 8kg/mm spring rate (448 Lbs/inch)
Ideal for daily driving or street strip use. Provides a smooth responsive ride with greatly improved cornering control and feel. Spring rates can be switched from front to rear. Independent track testing by professional race car drivers has shown over 2+ seconds a lap faster times over stock and other entry level suspensions.
Sport full coil overs:
Front 12kg/mm spring rate (670 Lbs/inch)
Rear 10kg/mm spring rate (560 Lbs/inch)
Increased Spring rates and more aggressively valved shocks provide a street able ride with race track bread performance. Track tuned, our sport suspension offers true race car handing performance and feel. Yet still suitable for road use.
OMNI Drag Rear Coilovers (Available with 12k Front setup)
OMNI Slip-Over Coilovers
OMNI Front Camber Arms
OMNI Rear Camber Arms
OMNI Test Pipe- Availble in JDM and USDM Fitments
OMNI Rear Lower Control Arms
OMNI Front Lower Control Arms- OMNI is the only manufacturer of this Product!!
OMNI ValveTrain
Modified by ImportAutoPerformance.com at 11:49 AM 8/24/2007
Modified by ImportAutoPerformance.com at 8:47 PM 9/14/2007
Tech Info Below:
Cycle stroke: 50mm
OMNI ValveTrain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyloazn »</TD></TR><TR><TD CLASS="quote">you have pm</TD></TR></TABLE>
Thank you for your orders! All PM's replied.
Ordered a set of omni sport coilovers for iap yesterday. Excellent service, great price
. Highly recommended
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA RR »</TD></TR><TR><TD CLASS="quote">Ordered a set of omni sport coilovers for iap yesterday. Excellent service, great price
.</TD></TR></TABLE>
Thanks for the business and the post. You will love this suspension!
.</TD></TR></TABLE>Thanks for the business and the post. You will love this suspension!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no-psi »</TD></TR><TR><TD CLASS="quote">Send me a price on some tylite coilovers for a 93 del sol</TD></TR></TABLE>
PM Sent.
PM Sent.
.</TD></TR></TABLE>
Thanks for the business and post. You will love these coilovers.
.</TD></TR></TABLE>Thanks for the business and post. You will love these coilovers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHyGuy »</TD></TR><TR><TD CLASS="quote">bump for a awesome seller</TD></TR></TABLE>
Thanks for the business and post!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf »</TD></TR><TR><TD CLASS="quote">do you know if omni will make the front lca's for the EF ?</TD></TR></TABLE>
I am sure they will come out with them in the future, however, currently they do not have an estimated time. Thanks
How much are the front lower control arms? And how much for the slipver coilovers? Do they fit over koni?
